Guard your cat!
Discussion in 'Gen 2 Prius Accessories & Modifications' started by mathewjg, Jan 23, 2019.
  1. mathewjg
    mathewjg Member
    84
    49
    During a quick visit to a supermarket in North east London,UK my catalytic convertor was stolen. The offence was captured on CCTV and it took about two minutes in total ..these guys could make a fortune working on a racetrack. As it was a crime, my usual recovery company could not collect the car and I had to therefore go through my insurance company. The recovery guy told me that several other Prius's have been attacked recently. Apparently some sort of pipe cutter is used. Not sure how much a replacement would cost normally but I have heard that they contain orecious metals and e sent abroad for the metals to be extracted as it's not a simple task.Annoyingly my insurance has a excess £300. If the crooks are caught then that is recoverable but no doubt they used a stolen car or number plates. So be careful where you park
    52,863
    this is shocking! why do they want your cat for? what are orecious metals?(n)
  3. Mendel Leisk
    42,355
    mathewjg likes this.
  4. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    SFO likes this.
  5. bisco
    52,863
    seems like a low margin effort
  6. mathewjg
    mathewjg Member
    84
    49
    bisco and Mendel Leisk like this.
  7. bisco
    52,863
    thank you, i am familiar with spell check :mad:
  8. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    that's what happens when you live somewhere that thieves know they won't get shot. in Virginia, an open carry state, crime is relatively low because criminals do know many of us are armed, as we should be.
    cats used to be good for about $50 each at the scrap yard. now they only give $20 or less. they have platinum in them in the core.
  9. Classic Car Guy
    Classic Car Guy Active Member
    504
    135
    Northwest, USA
    Time to resurrect this threading. The tweakers are out there and hitting all over US. Any updates on reliable catalytic guard. Or is it still the same Double 00 Remington.?:eek:
  10. romad
    romad 2004 Prīus Base Former Owner (Sold 13 May 22)
    320
    57
    Prescott, AZ
  11. Mendel Leisk
    42,355
    Check your link; at least for me it's showing a page of various items.
  12. romad
    320
    57
    Prescott, AZ
    Here is the expanded link:
  13. JahT
    JahT Member
    145
    77
    Mine is arriving tomorrow and I plan on installing it this weekend. Looks similar shape to your link, but I got it on eBay for a little less $75-80, but not sure if I get the screws and rivets as they weren't pictured. I will let you know how it goes.
  14. romad
    320
    57
    Prescott, AZ
    Looks like labwork's ebay store has 4 different designs for the 04-09 Prius:
    catalytic converter shield 2004 Toyota Prius Base 1.5L | eBay
    #14 romad, Feb 25, 2022
  15. JahT
    JahT Member
    145
    77
    I noticed that, mine has the cut-outs of the first one from the left, but has the outer profile on the 2nd from the left. I am not sure why some of them have the (2) corner protrusions and some have (1) like what I got. I didn't see any difference in coverage in the ones with mounted pix, so I got the one that I thought had the best cut-out slots so the smog place can read my serial number off of the Cat, and it would get good air flow, but I think they are all similar with round or slotted holes. I will report back if I can figure out why there are two different outer profiles/shapes.
  16. romad
    320
    57
    Prescott, AZ
    Where are you that they want to read a serial number on the convertor? Even the California People's Republic never required that when I lived there. Come to think of it I've never seen a serial number on convertor.
  17. JahT
    JahT Member
    145
    77
    It was mentioned here, I think they are supposed to. I am in CA, but I think it depends on the shop, and tech, and day, etc. I am sure you could find a shop that didn't care.
  18. romad
    320
    57
    Prescott, AZ
    Ah, I think you may mean a CARB Executive Order label. An EO label is required if you install an emissions related non-OEM part showing that CARB has approved the part. This label is to be either on the part or as close to the part as possible (if the part is not easily visible). Usually the label is just put on the underside of the hood as that is the most convenient. So it isn't a serial number but rather an EO number. Of course if the cat is replaced at a dealer then it isn't non-OEM usually, but if done by say, a muffler shop or non-dealer repair shop, then they should put the EO label somewhere. The only way I've ever been able to actually a cat clearly was when my cars were up on lifts, which is something your normal smog test shop probably won't have.
    BTW, I still had the California BAR Smog Check Manual PDF on my computer so I was able to read the visual inspection requirements where I saw the CARB EO mentioned. Glad I'm out of the CPR and no longer have to have my cars smogged.
    JahT likes this.
  19. JahT
    JahT Member
    145
    77
    I just wanted to report back that I just installed the cheaper ebay Cat Shield and it went on easy. I chose the one with the long slotted vent holes and the "missing corner" on the driver side, but it seems like they will all work the same regardless of shape.
    How I did it:
    attach the front 3 nuts first, not full tightened but snug so it can be shifted
    then reach back and center the back on the frame rails
    then tighten the front nuts a bit more
    then put a wood 2x4 between the cat and the metal shield, the 2(1.5)" side
    then I lifted the panel on the sides against the frame rails, it should bow down in the middle due to wood block
    then I put in one end screw on each side
    pulled out the wood block and checked for good clearance between Cat
    then I put in the the rest of the screws/rivets as it came with both
    Only took a quick drive so far, but no noticeable rattles or noise.
    Classic Car Guy likes this.
  20. Classic Car Guy
    504
    135
    Northwest, USA
    I have a question..
    How thick is the shield? or atleast can you bend it like a cardboard paper?
    Do you have the link or name of the shield?
    Thanks....
