Gunning it freeway MPGs
Discussion in 'Prius c Fuel Economy' started by mremaximus, Aug 16, 2012.
  1. mremaximus
    mremaximus "I can't wait to start hammering people" Bubbles
    98
    From parts unknown...
    So I did a fast freeway commute, and actually floored it for a few miles to keep from being edged of the road by crazies. I was surprised though, 8.7 miles and speeds ranging from 65 to 82, and most consistently 75ish, but I got 53.1 it was a little hilly towards the end, I was pleased.
    By-the-way is that the traction motor that kicks in with a burst of power once it's floored and you push a little more? Must be...
  2. Oldwolf
    Oldwolf Prius Enthusiast
    816
    106
    NC
    2016 Prius v wagon
    That is surprising, I agree.
  3. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    No. Firstly, if you are getting more after you floor it, it is the Fred Flintstone effect. Secondly, the motor generators are almost always providing some power. See Toyota Prius - Power Split Device
  4. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    cwerdna likes this.
  5. col127
    col127 Member
    345
    Illinois
    wow that's impressive. i drove 330 miles and only got 50.9MPG - speeds were around 71MPH the entire time... i was driving pretty conservative too! I have no idea how all you folks are getting such great MPG!
  6. nanonano
    nanonano New Member
    I too would like to know how ya'll get such good mpg. I drive about 112 miles/day, almost all interstate. I keep it at 70mpg and am getting about 46mpg in the C.
  7. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Slow down and learn how to glide. 70mph with the AC on full blast with zero gliding will seriously drop mpg potential.
    RocMills likes this.
  8. mremaximus
    98
    I imagine that my mpg's would have declined if my trip was longer. It was a very calm day, with a level road until the last little bit.
  9. col127
    col127 Member
    345
    Illinois
    Is it possible to glide at highway speeds? Someone said it wasn't! If so, how? :)
  10. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Yes. It's called warp stealth (WS). Obviously you won't do it when cruising steady state but you can use it on hills and overpasses. You should also be using it at every off ramp. Just beef ore you take an exit, lift off the throttle then reapply just enough pressure for the bar on the HSI to disappear between regen and the EV section. It's ok for the bar to be in the EV section just a little bit if that helps you until you get used to finding the right pedal position. When traffic is really light you can enter WS well before an exit and glide for a very long time. Do this enough times and your mpg will start to creep up. Soon you'll get the hang of it and you'll find more and more opportunities to glide. This is how many people get above EPA fuel economy. Combine this with lower speeds and you enter the realm of the 60mpg folk. :)
    brucepmiller and frugaldriver like this.
  11. backslash
    backslash Junior Member
    LA
    I drive 44 miles one way to work, from what I get driving 72-74 mph i get 53ish mpg but when i drive 68-70mph i get 48-48mpg.. AC is just on vent, meaning its off but blowing air from outside. Does momentum play apart at higher speeds? Anyone have similar experiences?
  12. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    If you were to perform this test in the standard A-B-A method you would find that the lower speed yields higher mpg. I suspect that your observations are skewed because of terrain/temperature differences.
  13. chicagoaficionado
    chicagoaficionado Junior Member
    57
    23
    Chicagoland
    You guys have such looooooonnnnngggggg commutes to work! No wonder you bought this amazing car.
    frugaldriver, Rob.au and MandyTee like this.
  14. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    Aye, mine is 49 miles one way. I couldn't fathom driving something that gets less than 50mpg now.
  15. chicagoaficionado
    57
    23
    Chicagoland
    Well hopefully you're pulling a 4/10 work week at least. I would just move. The water must be really sweet where you live too.
  16. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    My significant other makes much more than I do and gets much worse fuel economy so she gets to choose where we live. Hence her short commute. lol Besides, my commute is the reverse of normal traffic so I fly through. She would be stuck for an extra hour or more at peak times.
  17. Corwyn
    2,171
    659
    23
    Maine
    No.
  18. Corwyn
    2,171
    659
    23
    Maine
    Dup. please remove.
  19. Izham Aziz
    Izham Aziz Junior Member
    67
    Kuala Lumpur
    19KM/L = 44MPG shown in average from start MPG gunning it at 100-110mph for about 20kms or so, the whole 200km trip average was 22km/l = 51MPG with the rest of the journey at 45-70mph (80-120kmh). This was with eco mode off, AC set to 24C, night driving with lights and stereo and NAV on.
    I've done shorter hooligan run before, initially the FC will be 15-16KM/L (37-40MPG) but after a few kms the average will rise up to 18-19KM/L (42-44MPG) pedal to the metal.
  20. SILVERPC3
    SILVERPC3 New Member
    Dallas TX
    I am farely new to the C, but I am finding out its not much diferent than an ICE only car. There are many reasons why some get better MPGs than others. Elevation, temperature, wind, humidity, and driving style are just a few examples.
