Gutless in EV mode
Discussion in 'Prime Main Forum (2017-2022)' started by MikeDee, Oct 11, 2017.
  1. MikeDee
    MikeDee Senior Member
    1,581
    597
    San Francisco Bay Area
    While entering the freeway on an on ramp I mashed the pedal to the floor. Acceleration was less than adequate. Should have had it in EV Auto mode. Barely merged in front of a semi. Beware. EV mode seems like it has a lot of power but it doesn’t. Don’t confuse low end torque with power. YMMV
    iPhone ? Pro
    jaqueh likes this.
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    You are claiming that these issues stem from EV.
    I suspect that the root of these issues is that you have the vehicle in ECO mode. PWR mode will handle much better for you.
    Data Daedalus likes this.
  3. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    If in doubt or you know the drive will be demanding, that's exactly what EV-Auto is for.
    For predictable drives, like the daily commute. It's easy to know whether the default EV is enough.
    Data Daedalus, Mark57 and alexcue like this.
  4. alexcue
    alexcue Active Member
    346
    311
    So Cal
    I guess because I had a previous Prius I'm used to the capabilities or lack there of, of this vehicle. As john1701a said, EV Auto is my friend, but I don't push it. If I'm in places where there's lots of hills., ie the Grapevine, I just leave it in Power mode also. Keeps me out of trouble. I don't like driving in the Trucker's lane(s) if I can avoid it.
  5. Qmo
    Qmo Member
    61
    52
    Sunnyvale, CA
    I have mine on Power mode now and I feel it's more powerful than my Honda Odyssey
  6. Mark57
    2,945
    2,740
    OK
    Just remember, 100% throttle is 100% throttle no matter what mode you are in. In PWR mode you don't have to push as hard to get to it, but at the bottom, it's still the same.
    If you've got it locked to EV only, then there is no ICE to help until you reach battery levels or speed levels to make it kick in. That's what EV Auto is there for.
  7. MikeDee
    1,581
    597
    I’ve had this car almost a year now and put on over 10,000 miles and this is the first time I really needed the power. In my opinion, when you mash the pedal to the floor, the ICE should come on, but it isn’t designed to do that. If I could set the default mode to EV Auto, I would but you can’t. I should have thought to push the EV auto button, but didn’t.
    #7 MikeDee, Oct 11, 2017
  8. MikeDee
    1,581
    597
    That is an illusion. Power mode, eco, or normal mode, only the throttle is remapped. Full throttle is the same amount of power regardless of which of these modes you are in.
    Qmo and jerrymildred like this.
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    As @Mark57 and @MikeDee said, floored is the same in any mode -- 100% throttle. The lack of power was from not combining the ICE with the electric in EV only mode. The perception that you have more power in PWR mode is just that -- a perception -- because the power comes with less pedal travel. Read the manual. I'm sure it's in there. ;)
  10. bisco
    52,657
    one of the big complaints with the pip is that the engine comes on when you mash the pedal.:p
  11. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    If it did, I wouldn't have bought it.
    Even if it did, it would make no difference unless the engine were already warmed up because the car won't let the engine run a high power during warmup.
    I have one very difficult merge on one of my common routes. I just plan ahead for this one, which I always do in Ev only. If this merge was a problem for you, you shouldn't have attempted it.
    The car still doesn't perform as it should or as Toyota claimed it would. If it produced the 76kW they said it should (or 68kW as others have stated Toyota Europe said it should) it would perform better than it does.
    bwilson4web likes this.
  12. MikeDee
    1,581
    597
    What’s the Prime’s 0-60 mph times in EV, EV auto, and HV modes?
  13. Lee Jay
    5,850
    4,036
    I've posted that information in a thread with an easily searchable title. Ev and Hv, that is, since I've never used Ev Auto. It would be the same as Ev on a cold engine and the same as Hv on a warm engine, most likely.
  14. Lee Jay
    5,850
    4,036
  15. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    If someone does have a known merge, hill climb etc where they know they will need ICE, or even just prefer to have it, would the best thing be to switch to HV a couple of miles or so prior?
  16. bwilson4web
    16,474
    Could you provide Google Map or Google Earth coordinates for the ramp?
    This would help us understand distances and grades.
    Thanks,
  17. KMO
    KMO Senior Member
    2,022
    744
    Finland
    2023 Prius Prime
    The European version would always do that - there's no "never use the engine" mode.
    If you ask for full-throttle it starts the engine to give maximum power. Its default "EV" mode is the equivalent to the US "EV Auto", and even its "EV City" would also use the engine in the same circumstance.
    I guess they figured "pure EV operation" was a big US selling point, so made it not only an option, but the default there.
    Not sure how you'd even measure the electric 0-60 time in Europe - you'd struggle to stop the engine from coming on.
    Wonder if there is a regulatory thing - is it acceptable to have a mode setting in a car that inhibits the response to maximum accelerator pedal? The fact that the "pure EV" mode isn't available at all in Europe makes me wonder if there is some regulation that prevented it.
    I doubt that's correct. Previous Priuses will run the engine at high power when they'd rather just be warming-up if the pedal is pushed hard enough. So I'd expect high power almost immediately. Maybe not maximum power, but certainly a boost from electric-only.
    Trollbait likes this.
  18. Lee Jay
    5,850
    4,036
    Previous Prius didn't have this much power in Ev. To be a boost from EV the engine needs to be flat out because the difference between Ev and Hv is so small. In fact, Ev is more powerful until about 25mph even against a fully warm engine.
    Because of the power split system, engine power doesn't just add to electric power.
  19. Lee Jay
    5,850
    4,036
    I integrated these numbers to get a distance from the starting point. Ev is actually ahead until 35mph. Even with Hv's superior high-speed acceleration it's still less than a car length ahead by 50mph (only a 10 foot advantage). It's a just less than 2 car lengths advantage by 60mph. To give you an idea how small that is, the recommended distance between cars at 60mph is 12 car lengths (2 seconds).
    In other words, the difference between Ev and Hv for highway merging is so small one might consider it negligible.
  20. ct89
    ct89 Active Member
    323
    266
    New England
    That's assuming a start from zero. If someone is heading up/down an on-ramp at say 30mph and decides their little Prius can out muscle a big-rig, would you get a different result if you looked at the delta between 30 and 75mph?
