H11 to H9 Headlight Bulb Conversion
Discussion in 'Gen 3 Prius Accessories and Modifications' started by zebelkhan, Sep 23, 2012.
  1. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    Thanks, I'll try to find one of those bits for next time.
  2. lemonsama
    lemonsama Junior Member
    GG, CA
    I did the conversion and used it for about 4 months until I retrofitted some RX350s and from the limited use the bowls were fine.
  3. mediahound
    903
    155
    Good to know. Apparently it runs only a few degrees hotter than stock.
  4. Prius-Paul
    Prius-Paul New Member
    16
    nice info..
  5. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Still running H9 bulbs in both of our vehicles. No problems whatsoever, very satisfied with output. (y)
    Bought some spare bulbs too, since I'm sticking with the H9 setup for the long term.
    SCH-I535
    king mob likes this.
  6. xliderider
    8,140
    3,280
    Honolulu, HI
    Passenger headlight burned out today at 16 months. Replaced both sides tonight with new H9 bulbs.
    The Camry's H9 bulbs, installed at the same time as the Prius' are still OK.
    jzchen and scrappy like this.
  7. PeterHaas
    PeterHaas Member
    152
    29
    Monterey Bay, CA
    The fuse is there to protect the "feeder" (the circuit's wiring). Each feeder capacity in AWG (or square mm) has an associated maximum feeder capacity in amperes.
    Installing a higher capacity bulb, but retaining the same fuse rating, will not lead to electrical problems.
    It is installing a higher capacity bulb, and increasing the fuse rating, which may lead to electrical problems.
    #27 PeterHaas, Jun 19, 2015
  8. Markee
    Markee Member
    336
    South Florida Broward County
    For people who have already tried out a few different H9 bulbs could you please post which bulbs you find work best for road visibility ?
    #28 Markee, Jun 20, 2015
    Prieth likes this.
  9. xliderider
    8,140
    3,280
    Honolulu, HI
    Osram H9 clear bulbs from Germany are what I use. 15 months now and still burning bright on my Camry. One bulb burned out at 14 months on the Prius, replaced both bulbs last month.
  10. Markee
    Markee Member
    336
    Where you getting them at like what watt bulbs are you using to many different kinds of bulbs out there wouldn't want to buy the wrong ones
    Maybe you have a link or a part number for the particular bulb your using ?
    Also I'm reading about the H11 to H9 conversion harness You seen one out there that allows you to go from H11 to H9 without having to hackup the bulbs ?
  11. xliderider
    8,140
    3,280
    Honolulu, HI
    Buy the Philips bulbs from Amazon:
    they are German made and are highly reviewed by people who are doing the conversion from H11.
    Even if you get the H11 to H9 harness, you still have to modify the tab (one of three) at the base of the H9 bulb to make it fit in the H11 bulb mount at the back of the headlight housing.
  12. Markee
    Markee Member
    336
    Can you please post me a link or give me a part number for the exact bulb your talking about ??
  13. xliderider
    8,140
    3,280
    Honolulu, HI
    I put a link in the post above, search for B00480KOP4 on Amazon. It will bring up the correct bulb.
    Markee likes this.
  14. Markee
    Markee Member
    336
    #34 Markee, Jun 20, 2015
  15. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    I've been running the H9 German Phillips bulbs for a week now and can report this mod is legit. Great output from the low beams, enough so that I'm going to put off an HID conversion for the time being, anyway. Anyone considering this mod really needs to just get it done. It's got to be one of the best dollar for dollar Prius mods.
    Thanks to mediahound for the the how-to video and xliderider for the positive feedback regarding the mod in numerous posts/threads.
    king mob and xliderider like this.
  16. gbrowndsl
    gbrowndsl New Member
    socal
    You can use a laser thermometer to measure the temp, it will be a big difference but not enough to melt anything. I opted for an H11 HID conversion and the projector does a great job of cutting off the light and not causing glare or scatter.
  17. xliderider
    8,140
    3,280
    Honolulu, HI
    I'm interested in the temperature differences you measured, stock vs H9 vs HID. But you'd have to try to standardize the readings by taking them all during the day, or at night, and not have any major seasonal temp differences in the environment etc.
    Also, cold engine compartment vs warm/hot engine compartment would affect measured temperatures.
  18. John Molani
    John Molani New Member
    Austin, TX
    Just purchase two H9 bulbs. Didn't even have to cut off the metal, just the plastic above the plug inside. Much brighter than the H11. Had a HID kit as well from Morimoto which is a good brand, but they did not fit within the housing. Lower temp output than the Halogens, brightness was good too, but too many items to harness within the engine bay, felt it was not only a hassle but just too much money as well. HID kits (the good ones) are $100 or more (Paid $165 for mine).
    H9's gave a hotter temperature but not much different than the H11's.
    The conversion is pretty easy and a good hack for more light at a very low price.
    Tried LED's as well from Kensun but they were the worst. Unless it's the manufacture LED's (like the Package 5 Prius Gen 3), then it's no good.
    I currently drive a Gen 3 Prius.
  19. howardc64
    howardc64 Member
    141
    Pacific Northwest
    Tried a bunch of HIDs and LEDs and unsatisfied with all of them. Most cheap 35W/55W HID ballast don't produce enough light as they are probably not really 55W (I read somewhere most of them are just over boosted 35W and some have even melted car's wiring). Xentec's bigger size 55W ballast worked well but seems like lots of HID bulbs (even ones say 55W) can't handle it (flickers). Eventually, one of the Xentec ballasts started eating bulbs and make a buzzing noise at startup. Cracked it open and find rubber coated electronics for moisture protection solution (and was poorly done) that surely isn't very good for heat dissipation. Here is the pic with all the rubber layers scraped off.
    For LEDs, I tried the popular Beamtechs recommended here, also way too dim even after raising the beam alignment per various poster's suggestion.
    Finally going back to Halogen and opt to go with the brighter 65W H9s. Modification was really easy. Per post #38, didn't mess with the triple metal keys (made it a little harder to install the passenger side with the tight spaces, had to do it with the wiring harness/connector off for full freedom). Just cut off the shorter plastic key inside the plug. Here are the tools I used
    - Styrofoam bulb protector that came with all the HID bulbs I bought
    - Exacto knife to score both side of the plastic key inside the plug. Make sure you score it all the way to the bottom.
    - Ultra narrow needle nose plier to break the key off, came off cleanly without much force. Maybe scoring it with exacto knife is not even necessary?
    - narrow file to clean up the little bit of bump that is left. Hardest part is all the way at the bottom where the plastic make a 90 degree bend. If you have a file with a filing surface on the end of the tip, probably make it a lot easier.
    #39 howardc64, May 30, 2019
    Prieth likes this.
  20. king mob
    king mob Junior Member
    Thank you all for this..
    m.wynn likes this.
