Hacking the solar?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by HTMLSpinnr, Jan 22, 2009.
  1. Flying White Dutchman
    4,376
    313
    i also wanted to place a solar panel under the front solar roof haha
    not use it as a solar roof but for solar energy haha
    to protect solar cells i put behind it
  2. LaurieTx
    LaurieTx Proud new owner!
    97
    Why no posts since the details and the cars became available? Were I knowledgeable enough and so inclined, the hack I'd like to see would to put the remote A/C on a timer instead of the key fob. Being able to it set to turn on the time I usually leave my desk would be awesome--then it would actually have 3 minutes to run before I get to it. By the time you are close enough to activate it from the remote, it will probably be only 30 sec till you reach the car!
    But I am hoping the ventilation to reduce the inside temp while parked works at least to a moderate degree. We've already had 15-20 days over a hundred here in central Texas. We usually don't get this bad until mid to late July. It's going to be a very long summer. :)
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    I've looked through the EWD's and felt it would take more effort and skills than I was capable of on my own.
  4. LaurieTx
    97
    Ah, well. Maybe someday the programmable A/C will be a reality someday. One can dream. :)
    How has the ventilation been working for you in AZ? Do you think it was worth it?
  5. HTMLSpinnr
    5,341
    920
    251
    Feel free to dig through the other threads where I've reported on it's relative effectiveness and shortcomings.
  6. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    so.. since this subject is still flying around...
    i know.. the geek factor..
    but still.. Toyota engineers didn't tap into the solar panels because it created noise in the audio system.. too much noise.. so they isolated it. If you can figure out what interfearance or noise they are referring to.. and find a way to dampen it... i don't see why you couldn't tap it into the 12v... all we need to do is wait to see who finally gets a hold of the schematics for the pv system and it's wiring harnesses...
    My car has never seen a garage.. and in California i'm never worried about snow or hail.. so.. a solar roof would be rather sweat... :)
  7. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    FYI,
    One of Japanese Prius enthusiasts, the Japanese CAN-View guy, installed a PV panel to charge the HV battery on his 2G Prius.
    PV panel on 2G Prius (Japanese only)
    He is very good at designing the MPPT(Maximum Power Point Tracking) circuit for the PV panel.
    The energy gain per day is 30 to 50 cc of gasoline. It is very little gain, but gain is gain. :)
    Ken@Japan
  8. Flying White Dutchman
    4,376
    313
    not a aerodynamic installation but i guess driving slow city makes now differants
    what the watt on this panel? to the looks of it i say? around max 30 watt?
  9. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    It's 45W solar panel.
    Ken@Japan
  10. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi All,
    Seems to me that one could hook the solar panel up to a heater that is under the traction battery case for winter months. So, if the battery case temp is below 32F, the battery gets warmed up, instead of the ventilation fan spun.
  11. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    donee,
    I agree, and this idea could be extended to overnight use via a AC-DC
    converter, and not limited to just the Gen III. But there's much work and
    little interest shown in the past:
    http://priuschat.com/forums/gen-ii-.../57752-hv-battery-pre-heat-anybody-tried.html
  12. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Got any details or photos on how he rigged the charger? Seems that would be the tricky part.
  13. PriusCrazy
    PriusCrazy Blizzard Pearl for Me
    213
    28
    Triad, NC
    Just found this in the owner's manual. Not sure it's relevant, but wanted to post it here just in case...
    p.432
    When charging the 12 volt battery
    Never recharge the 12 volt battery while the hybrid system is operating. Also, be sure all accessories are turned off.
  14. TheForce
    3,461
    537
    Wheelersburg, Ohio
    So my understanding from google translation is that he is saving about 58ml of gas on a good day?
    If gas was $3 a gallon that would be a saving of about 4.5 cents per day?
    So if he was getting 60MPG this solar panel would get him almost to 61MPG?
    Am I correct on those numbers?
  15. carz89
    carz89 I study nuclear science...
    444
    47
    San Diego
    How did you come across this information? I'm a little skeptical about the noise. Power generated from PV cells is pure DC, which does not create electrical noise interference. I'm guessing it's the conversion to AC that's causing the noise.
  16. Tideland Prius
    16,678
    Very interesting. Is he taking on a new project and working on the 2010? It would be nice to make the solar panels work while the car is in motion rather than being dead weight.
  17. donee
    donee New Member
    2,956
    198
    Chicagoland
    This has been discussed somewhere else on PC in the past months. I am not so sure its noise in the audio system, or RF hash radiated by the panel. Do a google on Microstrip Antenna, and you will how close the panel mounted to a car body is to such a device. Any noise in the power converter would then radiate through the panel, and jam radio reception of all nearby cars. There are regulations regarding RF emisions of electronic devices. I imagine they could not come up with a solution fast enough. By hooking the panel to the fan, a relay could be used to switch the fan back to the 12 V system car is powered up.
  18. patsparks
    10,664
    569
    Adelaide South Australia
    But what is the aerodynamic losses?
  19. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    His schematics is here.
    He is saving approx 40 mL (5 JPY=5 cents) on his return commute.
    This makes his return commute mileage from 7.8km/0.26L=30km/L(70.6MPG) to 7.8km/0.22L=35.5km/L(83.4MPG).
    He doesn't own the 2010 Prius yet. Maybe, in the near future.
    His system is working while the car is in motion too.
    We know the base electric consumption on the 2G prius is approx 200W, therefore the 45W solar power helps the consumption a little.
    I think the aerodynamic losses are very minor.
    Ken@Japan
  20. Flying White Dutchman
    4,376
    313
    nice..
    this dc- dc converter is that only converting and showing some info about the energy provided by the solar panel or is it also shutting the dc- dc converter off when the SOC of the prius battery is getting to high? when standing in the sunlight to long when i is not driving it for weeks?
