Hacking the solar?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by HTMLSpinnr, Jan 22, 2009.
  1. Gary in NY
    Gary in NY Member
    153
    Poughkeepsie NY
    That is an interesting thread, thanks for pointing it out! Maybe someday I'll try one of these mods. I don't have a lot of need for charging external equipment, but maintaining the aux 12V battery sounds interesting. And if we do that, I suppose it would make that battery more useful for running equipment with the hybrid system off. Like charging other equipment (except this way, there's no guarantee you're not discharging it faster than charging).
  2. vallesj
    vallesj Junior Member
    98
    At 13.5 volts and around 2.8 amperes on sunny days is good enough to connect many type of devices
    Nexus 7 ?
  3. vallesj
    98
  4. vallesj
    98
    AzusaPrius and JamesCobalt like this.
  5. Solarpriusguy
    Solarpriusguy Junior Member
    Wow Sambra, you have done a great job collecting data and posting it for us. My Prius is often not used for a month or more and the battery is dead when i try to start it. This is a great solution. Thanks for doing all the work.
    AzusaPrius likes this.
  6. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    After that happens about twice, your battery is likely weakened and needs to be replaced.
    To prevent that from happening, the best solution is to connect it to a small automatic battery tender type charger.
    Standard 110V versions are readily available for about $35; solar ones might be available too, likely at a much greater cost.
  7. Solarpriusguy
    [​IMG] [​IMG] [​IMG]
    Just completed my Prius solar connection to a charge controller. My installation differs from Sombra slightly. Instead of locating the solar wire in the ceiling, I located the wire as it passes through the bottom of the rear left passenger door frame. Photo 1, To do this, just remove a 3 ft section of the molding at the bottom door frame. Put your fingers under neath it and pull up. photo2, It comes right out. You will now see a black cable harness. Where another cable joins it, remove the black tape around the extra insulation and remove the insulation. There are about 10 wires in the harness. There are just a few of larger wires. Locate the green one, that is the solar wire. Using a wire connector, connect this to about ten feet of #16 or 18 wire. photo3, Fish the wire under the seat and into the rear compartment. Fish the wire along the lithium battery compartment, over to the 12v battery. I used a Sunguard solar controller just like the one Sombra used. photo4 Once you have all the parts together, it takes just one hour to complete the installation.
    John
  8. Solarpriusguy
    Here is a parts list for the job:
    1. Sunguard 4.5 amp Controller ($37 on Amazon.)
    2. Inline fuse with 10 amp fuse
    3. Wire terminal connector kit (Walmart, $7.95)
    4. #16 wire, 10 ft.
    5. Black electrical tape
    Connect the fuse between the battery + terminal and the charge controller + battery connection.
    vallesj likes this.
  9. Easy Rider 2
    1,584
    258
    Ocala, FL
    Wow. I never would have believed that the solar cell designed only to turn a little fan would have that much output, as documented in the blog posts linked above.
    He did mention though that direct sunlight was critical so this solution won't work at all if the car is stored inside while not being used.....and maybe not well in cloudy areas too.
    And finally, a battery that won't hold up for 4 weeks of non-use has lost some of it's capacity already and if it looks like this solar charging system is going to work for you, it will work much better if you start with a new battery. Even this might not keep the old one alive very long.
  10. vallesj
    98
    Good job!
  11. Michael Cline
    Michael Cline Junior Member
    28
    23
    I strongly recommend using a Buck Step-down Converter instead of the charge controller. The ones without display are the best implementation since the display draws power. Example product: "RioRand LM2596 DC-DC Buck Converter Step Down Module Power Supply Output 1.23V-30V"
    Advantages of the Buck Converter are complete controllability and predictability, and plays really well with the fan. You can set your float/charge voltage as aggressively or conservatively as you like, I suggest 13.1. (The Prius charge system will handle de-sulfating, etc.). The buck converters are also dirt cheap @ around $2.50 each. Here are my original implementation instructions and notes: Solar Panel Mod charger | PriusChat
    As a side note, if you get clever with one of the "display" buck converters, you can rig a switch to turn off or drive the display from the input to eliminate leakage current from the battery when parked in the dark.
    SolarPriusGuy, excellent find regarding tapping the solar wire under the rear passenger door. Hitting that wire in the dash was the most complicated step of the upgrade when I first did this.
    #130 Michael Cline, Dec 7, 2014
  12. Solarpriusguy
    Here is a recap after completing the installation in December: Just returned from a six week trip while my solar powered Prius sat in the driveway. The 12v battery is fully charged and I had no start up problems. Of course, the car was outside with no obstructions to full sun for the panels.
  13. GregP507
    GregP507 Senior Member
    3,002
    481
    I'd recommend maintaining the 12V battery with the solar panel, not trickle-charging it. If a reliable charging current can be derived from the solar panel, through a charge-controller circuit, it could alleviate the anxiety associated with the inevitable slow-drain on the 12V auxilliary battery.
    I've gone into much detail on the subject of trickle-chargers vs. battery-maintainers in other threads. In either case, circuitry is required to limit the current being applied to a battery once it is fully-charged, otherwise the battery is sure to be damaged by over-charging.
  14. Easy Rider 2
    1,584
    258
    Ocala, FL
    Or you can use a source that isn't capable of providing enough current against a full charge to do any damage.
  15. GregP507
    3,002
    481
    I think we're talking about enough current here to top-up a Prius battery. The easiest way is for the voltage to be controlled to deliver the right amount of current to give it a proper charge, although current-limiting is also an option. Such a controller should also monitor the charge level of the battery and deliver programmed charge cycles in response to monitoring. This is very similar to the way a battery-tender works. The simplest way is to set the maximum voltage to the level of a full-charge on the battery, but this can cause problems as the battery ages.
  16. Dmaximum
    Dmaximum Junior Member
    Palm Beach FLorida 2006 package#4 Silver Mica
    great job VallesJ, one thing.. Can you detail your use of the capacitor in your install
    Thank you
  17. vallesj
    98
    What capacitor? Are you meaning the diode?
    Nexus 7 ?
  18. Dmaximum
    I must have read it somewhere else...someone used a super capacitor as a buffer for the solar panel for partially cloudy days. I have been researching this mod for many days..so too information overflow. Since you mentioned it..the diode size would be helpful.
    Thank you
  19. zombiegristle
    zombiegristle Junior Member
    I did this mod the other day using the instructions a few posts up and the SunGuard controller from Amazon. I'm curious, I don't have a way to test/measure it but would the solar panel be enough (hypothetically, on a sunny day in the southwest) to safely use the car as a solar charger for a phone/tablet plugged in by using accessory mode? Or would that still run down the 12V battery pretty fast?
  20. TonySS
    TonySS Junior Member
    Sweden
    Got very inspired by Solarpriusguy and I decided to do the mod on my Prius 2011. Solarpriusguy was kind to make the photos of his mod available on the forum again which made it much easier. I used a Victron BlueSolar MPPT 75/10 Controller with Bluetooth (bought on eBay) so now I can monitor the charging on my mobile (works with both Android and iphone). It works great with enough power to keep both the battery charged and run the ventilation fan. See attached photos.
    20180519_140841_small.jpg 20180519_135653_small.jpg 20180519_134217_small.jpg 20180519_140748_small.jpg IMG_8301_small.JPG IMG_8302_small.JPG
  21. AzusaPrius
    AzusaPrius Senior Member
    2,257
    950
    I second this and confirm it works as said.
    I am using a Renogy 10A Wanderer
    Controller purchased for $15
