Had Prius 2 days...won't start - HELP
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by curiouslystrong, Nov 22, 2015.
  1. curiouslystrong
    curiouslystrong New Member
    Chicago
    I drove my Prius (used, 2012, 69k miles) home Friday evening. It snowed that night and into Saturday morning, so yesterday evening I went out to the car to warm it up, brush it off, hook my phone up the the bluetooth, etc. It started up just fine, no problems, and then when I was done I turned it off and locked it (didn't drive it that day). Tonight I went out to drive to the grocery store, and that's when the problems started.
    I got into the car no problem, pressed the brake and the power button, and the dash screen came on, but then nothing else happened. No "READY" light appeared. I turned it off and tried turning it on again. Same deal. I tried a couple more times (I was wondering if the issue was due to the cold?), and at one point the lights on the screen just started flashing. Then they went off. I've progressively been losing functionality: less lights coming on each time I tried to start the car/investigate the problem, less happening each time the power button was pressed, the light on the power button turning orange at one point, then completely turning off, the key fob not working (i.e. door would beep at me when I tried to open it from the outside, but wouldn't unlock; also key fob won't lock the car anymore, I have to do it manually). I assume it's a battery issue, but I've only had the car since Friday evening and have only driven it once, so I'm totally at a loss here. What's going on? And what do I do to get it fixed?
  2. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Sounds like a problem with the 12V battery - lots of threads hereabouts on symptoms and possible solutions. "Search" is your friend, and I'm sure many other readers will chime in with suggestions! Good luck! …and Welcome to PriusChat!!! :)
  3. curiouslystrong
    Chicago
    Thank you for your reply! I did search for other threads, which was why I suspected it was a problem with the 12v battery - maybe it's that I'm such a newbie, or maybe it's that I'm in a panic, but I couldn't figure out what applied to my particular situation and what didn't, and some of the stuff went a bit over my head. I'll search again and see what I can find/make sense of...thanks again.
  4. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Welcome to the site. First, check the voltage of the 12v battery. If you can't open the hatch then hook up a trickle charger to see if the battery will take a charge.
    Did you try both fobs? If the battery in the fob is dead you'll have to use the mechanical key to unlock the door. Push the start button with the fob to get the computers booted up.
  5. curiouslystrong
    Chicago
    Okay, this thread (What happens when 12v battery dies? | PriusChat) has me about 99% convinced that it is indeed the 12v battery, though I don't have any way to independently confirm that at the moment. I am not very car-savvy, at least with regard to having a clue what's happening when something goes wrong. I think I only have one fob - and it doesn't seem like the fob battery is dead, just that the car isn't responding to the fob properly when I use it.
    I can find a lot of threads about DIY replacement of the 12v battery, but that is something I am absolutely NOT equipped to do. I'm not sure exactly what the best way to proceed here is. Do I call a mechanic who can come on-site to jump my car and then drive it somewhere to get serviced? Do I get it towed? Who do I go to in order to get the battery fixed/replaced (my local independent mechanic? a Toyota dealership? or the dealership at which I bought my car?) - and how do I know whether it just needs to be recharged or if it needs to be totally replaced? I've tried searching (both here and on google) and am not finding these particular answers...if there's already a thread (or threads), a nudge in the right direction there would also be very helpful. Thanks again.
  6. Patrick Wong
    18,210
    6,517
    Since you say you are not equipped to replace the 12V battery, the least costly approach would be for you to jumpstart the car (making sure to observe correct battery polarity) and drive the car to the service location of your choice.
    Of course if the jumpstart is botched you may end up with a four-digit repair bill if the inverter is destroyed so you must be sure about what you are doing. A mechanic is not going to come out to you for this purpose. A tow truck driver would do so but may screw this up.
    If you have any concern about being able to correctly jumpstart the car, then have the car towed to a Toyota dealership for diagnosis and repair. They will probably charge you ~$300 if in fact the 12V battery is at fault.
    If you were to DIY the cost of a replacement 12V battery would be ~$200. Hence the difference between those two choices is going to be $100 plus the towing charge.
    The way to determine whether the 12V battery needs to be replaced or not is to apply a 4A charge to the battery overnight, and see if the battery holds the charge or not. If the battery is more than 4 years old, in your locale with very cold winters, the battery should be replaced regardless. The age can be determined by observing the manufacturing date sticker on top of the battery (if original equipment). The battery bracket needs to be removed to see the sticker.
    Merkey, Robert Holt and WilDavis like this.
  7. bisco
    52,792
    did you spend any time in accessory mode? that can kill the 12v.
  8. curiouslystrong
    Chicago
    Thank you! This is very helpful. I appreciate your thorough response.
    I did not - it was on and ready (in "READY" mode? is that how it's phrased?) when I cleaned the snow off of it yesterday. My husband MAY have left a single overhead light on on Friday evening (I know he turned it on and I can't remember it being turned off, nor can I remember whether or not it was on when I got in the car both today and yesterday), but he seems certain that he did turn it off.
  9. bisco
    52,792
    ready or ready mode, correct. a single light overnight will also kill it. but don't tell him that. if he's anything like me, he'll just dig his heels in.:cool:
    what you need now is a jumpstart, trickle charger, digital voltmeter, or a good mechanic.
    usnavystgc likes this.
  10. fuzzy1
    10,688
    Regardless of anyone's certainty -- his, yours, or some sneaky 'not me' gremlin -- this is always one of the top suspects. And if this is what happened, a simple jumpstart should get the car running, at least in the short term. Longer term, if the car still has the original factory 12V battery, its is aged and may need replacement soon.
    If your household has a car battery charger, or a portable 'jumpstart pack', or can borrow one easily, this is the easiest way to get going. Given your admitted lack of car savvy, I'd steer away from any car-to-car jumpstart. The Prius is much more sensitive than traditional cars. As Patrick pointed out, botched jumpstarts are very ex$pen$ive. Too many new members have joined here just after experiencing such a problem.
    In the future, drained batteries from lights left on can be reduced (but not eliminated) by changing the offending lamps to low current LED models. While these will still eventually drain the battery, it will take more than one night to do so.
  11. curiouslystrong
    Chicago
    Thanks for your help, everyone. I called my insurance company's roadside assistance this morning and they sent out someone to jump my car. It's running and I managed to make it into work. I'm betting the culprit was, in fact, a dome light that was left on. I feel silly (I've NEVER done that before), but definitely relieved.
    PLSPUSH and usnavystgc like this.
  12. Mendel Leisk
    42,289
    Don't relax yet. A jump start doesn't revive a battery that's been significantly drained. A good drive will help, but ONLY a little. You may be back to square one, soon. You need to do one of the following:
    1. Get the battery tested by professionals.
    2. Get a digital multimeter (cheap ones can be acquired for around $20), and see what voltage the battery has, for starters. Then try hooking it up to a smart charger in the 3~4 amp range, let it run to completion, see what it's verdict is.
    #12 Mendel Leisk, Nov 23, 2015
  13. WilDavis
    2,493
    2,155
    49
    Smart meter? Perhaps you meant Smart charger? (…sorry, to be anal, but the devil is in the details, as I'm sure you know!) ;)
  14. JimN
    7,028
    1,117
    South Jersey
    Welcome to Prius Automotive Shop 101. The assembled faculty is always willing to help. A few basic tools aren't expensive and will pay for themselves.
    I like a BatteryMinder trickle charger. It is easy easy enough to "permanently" install, it can be found in a number of places, and is inexpensive. It will prolong a battery's life but but it resurrect a dead one.
    A digital multimeter is needed to check a battery's voltage. They are inexpensive and can be found just about everywhere.
    There are a number of replacement batteries to choose from. It is easy enough to shop around. Consider the warranty and the price. The battery is not heavy and can be swapped out in about half an hour with some basic tools.
    If you want to be self reliant there are many things that you can learn to do your self. You'll get a sense of accomplishment and will save yourself some money. There is also nothing wrong in paying someone to fix things. Some can make that choice but others can't.
    It is easy enough to inadvertently leave a light one. You may want to leave the one on the deck OFF. It doesn't throw a lot of light and it is the most likely suspect to drain the battery. Focus on identifying the problem and the solution. No one wins in The Blame Game.
    GrGramps likes this.
  15. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    692
    151
    Seattle, WA
    Change the 12V battery. Period. Age plus at least one deep discharge mean it's probably toast & will be unreliable even if you can get it jumped and running now.
