Had to "reboot" my Prius today!
Discussion in 'Gen 2 Prius Main Forum' started by lpleiss, Nov 21, 2004.
  1. lpleiss
    lpleiss New Member
    27
    Omaha, Nebraska
    Weird thing happened on my drive home from the car wash today. I wanted to turn up the volume on the radio and none of the controls responded. First tried steering wheel controls, then the nob and nothing worked. Finally I touched the Audio button and noticed it switched to the audio screen without beeping, which it's never done before. I switched between several other screens too, and it didn't beep, and the steering wheel controls continued to not work. When I got to a red light I decided to "reboot". I powered the car off and back on again (which for some reason doesn't seem like as a big of a deal as it would in a regular car). After that everything worked normally.
    I wish I knew what caused the odd behavior, and I seriously hope it was a fluke and I never see it again. Anyone else had to do a "reboot"?
    Luta
    '04 Salsa Red BG
    1 year anniversary with the car is 11/30.
    13,600 miles
    lifetime MPG 43.7
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    it has been reported here on PC before. You did the right thing, re-boot.
  3. Ray Moore
    Ray Moore Active Member
    857
    51
    Texas Hill Country
    I had to do it at around 5k but not since then. I have 17.5k now.
  4. DaveinOlyWA
    15,140
    610
    South Puget Sound, WA
    2013 Nissan LEAF
    once in 7000 miles have i had an issue that required a reboot.
    i have to say that's a much better track record than my Win98 machine....
    and before i hear upgrade cries, its one of 5 machines i have and its around as a file server and for the office suite on it, plus a few others that are not compatible with XP
  5. jimvitz
    jimvitz Junior Member
    94
    Oak Park, IL
    <div class='quotetop'>QUOTE(lpleiss\";p=\"52013)</div>
    That's how my MFD problems began. For several weeks after the first incident, everything was fine. Then it happened again, and then more and more frequently until the MFD screen never responded at all. Had it replaced today. All is now well.
  6. DBM
    DBM New Member
    36
    SF Bay Area
    Happened to us yesterday at 400 miles. I'll monitor the situation and post updates if necessary.
  7. stevesol
    stevesol Junior Member
    Midwest
    Same thing happened to me exactly once so far. I reported it under the heading "Strange Audio Problem" either here or at priusonline.com. This prompted a whole string of responses. Apparently it is a common problem, at least ONE time. I have not heard any reports of this being a recurrent problem. Some have noted that this was the first step in the failure of their multifunction display, but I wonder if that is a different issue. The steering wheel controls also failed during my episode, solved with a reboot. My display has never had any issues.
  8. Charles Suitt
    Charles Suitt Senior Member
    1,637
    Dallas TX
    MORE & MORE.. the Prius reminds me of Computer Days. One of the early computer lessons was: "If you have a problem, do a "RE-BOOT" (or "Clean Boot") and frequently the problems are solved.
    Since our PRII are very much computer controlled, RE-BOOTING seems appropriate and sensible.
    Just my 2¢ worth...
  9. Jim S.
    Jim S. New Member
    39
    Pasadena, CA
    Had this happen twice myself, never figured out if it was a particular sequence that triggered it, or if it was random.
Loading...
