Halogen light harness recall, anyone have it done yet?
Discussion in 'Gen 3 Prius Technical Discussion' started by mtnbkr, Jul 5, 2018.
  1. mtnbkr
    mtnbkr Junior Member
    27
    MD
    My dealership says they have no ETA on parts. I went in months ago and status never changes. Just trying to see if anyone has gotten it done. I have a 2010 Prius 3, if it matters.
  2. ASRDogman
    ASRDogman Senior Member
    8,052
    4,083
    Wow, I forgot about that! I received the recall AFTER I replaced the bulbs!
    I will have to check it out next week. Thanks!
  3. mtnbkr
    27
    MD
    Forgot as in never went to dealer at all to get it addressed, or forgot as in you're also waiting and it's been months, like me.
  4. ASRDogman
    8,052
    4,083
    I had forgot about the recall. It needs to be done by December this year I believe.
    I need to call Toyota and see if they have the part and when they can do it and how long it will take.
    I'd rather they give me the part and I'll replace it myself. Then I'll know it's done correctly.
  5. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I did it. Wasn't there for it, but was told they needed 2 hours, and replaced both bulbs and some wiring. Been a couple months and no burned out light bulbs.
    They were insistent to not call it a recall, but a warranty service...
    Raytheeagle likes this.
  6. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    The land of semantics :rolleyes:.
    mgb4tim likes this.
  7. ASRDogman
    8,052
    4,083
    Thanks, now I have an idea. It's probably a 20 minute job.
    I've worked at dealerships...
    Both my bulbs are only a month or so old/young. I'm not sure if my Prius has a wiring problem as I don't
    drive much at night anymore.
  8. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    The problem is the voltage the bulb sees. Since the Prius 12v circuit runs at about 14 volts, it fry’s the bulb sooner than it should.
    Pretty sure they just install a wire to drop the voltage to the bulb for the “warranty service”.
  9. ASRDogman
    8,052
    4,083
    Makes sense. It's probably a resistor wire. Like a fusable link.
    Thank you.
  10. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    So far no one measured how much voltage the low beams are after the harness recall fix :whistle:
    RMB likes this.
  11. ChapmanF
    18,975
    CR94 likes this.
