"Halogen" Tail Light Assembly
Discussion in 'Gen 2 Prius Technical Discussion' started by baumgrenze, Aug 24, 2017.
  1. baumgrenze
    baumgrenze Junior Member
    44
    I'm on the web and looking to replace the passenger side tail light assembly on my '04.
    Parts.com advertises a 'halogen' tail light assembly. I chatted with a sales rep and gave up. They advertise it as:
    Replaces O E Number : 8155147071
    Replaces Partslink Number : TO2819135
    Could there be a replacement that allows a bulb to be replaced when the brake light fails?
    Does anyone have experience with these?
    Are there any brands to avoid?
    thanks
    baumgrenze
  2. Kevin_Denver
    Kevin_Denver Active Member
    581
    422
    Denver, CO
    I believe "Halogen" is referring to the turn, reverse, and/or running lights bulbs. As far as I know, there is no replacement that has an interchangeable brake light; if the brake light goes out, you have to replace the whole thing. Failures are very rare, so if you replace it, I doubt you'd ever have to do it again.
    Data Daedalus likes this.
