Halogen to Led headlamps project
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Blizzwhiteprius, Nov 2, 2013.
  1. priusplugin2014
    priusplugin2014 New Member
    SF
    2014 Prius Plug-in
    where can i get the halogen to led harness? can you provide me info in where i can find it to purchase it?
  2. xcuter
    xcuter Active Member
    303
    182
    How much did the replacement brackets cost?
  3. Robert Santana
    Robert Santana New Member
    Scottsdale
    Newbe here and learned a lot from this thread as well as Genetix. So I'm shopping around for the ballast and I'm not sure if I'm getting the right one. Toyota Parts page has 81107-47380 listed as the control module and it looks like I need a cover too? Is this the correct part. I've looked on here and saw that some other guys used ballasts with different part numbers. For example I've seen 85967-47020 on other threads but this part is listed for the Prius V (as in the letter) not the Prius 5. Any assistance on this?
    sfv41901 likes this.
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    All depends on the year headlight.
    The 10-11 LED use a different LED ballast than the 12-15 LED headlight
    81107-47380 is for the 12-15 headlight & needs the cover
    iPhone ?
    torparts likes this.
  5. Robert Santana
    Scottsdale
    I'm trying to put the 2010-2011 into a 2012. These are the ones with the circular lights correct? Which ballast is correct for that. one?
  6. Robert Santana
    Scottsdale
    I do have an iPhone if that's what you were asking.
