handling difference 15'' wheel vs 17''?
Discussion in 'Gen 3 Prius Main Forum' started by bionicman, Dec 25, 2010.
  1. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    Not really that accurate though because surface conditions make a huge difference in stopping differences. Same day, same surface, much better test.
    TFLcar.com did a test on a Prius V and listed the 60-0 distance at 114 feet.
  2. evpv
    evpv Active Member
    692
    341
    West Coast
    2019 Prius Prime
    Nope, the Bridgestone Turanza's on mine are described by tirerack as "Standard Touring All-Season" with a treadwear rating of 260.
    "The Turanza EL400-02 and Turanza EL400 w/UNI-T are Bridgestone's Standard Touring All-Season tires developed to meet the Original Equipment and replacement tire needs of drivers for their sporty coupes, sedans and vans. Turanza EL400 tires are designed to provide a luxury appearance, long wear and responsive handling along with dry, wet and year-round traction, even in light snow."
  3. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I wouldn't say it's minor. A II - IV with 15" tires has more manuverability in tight parking spaces than a V would. Toyota dialed in a larger turning radius on the V to avoid interference from its wider 17" tires.
  4. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    EL400-02 is available as LRR in selected sizes but I guess 215-55/17 isn't one of them so your point stands.
  5. Thai
    Thai Prius Neophyte
    1,197
    89
    Yes, but, i have not had no issues in any parking lot nor when making U-turns...because the Prius is so compact as is. Sure, i am sure if you put the Prius in a fishtank, then yeah, it makes a little difference....
