Handling with Bridgestone Ecopia tires on 2008 Prius Touring?
Discussion in 'Gen 2 Prius Main Forum' started by woodenpaddler, Mar 7, 2013.
  1. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    Ah, thanks for the update.
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    I replaced one Ecopia at the Goodyear store and it had a higher load rating (91) than the OEM's (89) so u r right. not the same despite the "similarity" in names... ;)
  3. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    I currently have the Ecopias on my 2007. I'm not in love with them, but I don't dislike them either. They do have an unusal characteristic that I've noticed here in Ohio. They are slippery when the roads are wet more so then most tires i've used. However the performance in snow is actually decent and better then I anticipated. As for fuel economy I don't seem to have any noticeable gains or losses from them.
  4. woodenpaddler
    woodenpaddler Junior Member
    17
    Maine
    I have more data now after 14 tanks of gas and 4783 miles on the Bridgestone Ecopias. The average mgp improved to 43.3 mpg. While I would expect mpg to improve now that the weather has gotten warmer, this is much better then the old Insignia SE200's which for the same months in 2012 averaged 40.1 mpg.
    What I don't like about the Ecopias is the handling is more more wiggly.
    F8L likes this.
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Thanks for the update. :)
    The handling is the main gripe with these tires. They are great in most other respects and the FE is good.
    Merkey likes this.
  6. Merkey
    Merkey Active Member
    315
    285
    Birmingham, Michigan
    I had the Ecopia 422s put on last Nov. & currently have 6K miles on them. They performed decently in the snow and now that it's getting warmer I'm getting about 5 more mpg than previous Michelin Destiny tires. They seem to handle well enough for my non-aggressive driving style.
    F8L likes this.
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    That is pretty much how I represent them. If you want great fuel economy, decent wear, comfort and a bit of security in the snow then the tire is great as long as you don't put a huge value on performance handling. :)
  8. Merkey
    315
    285
    F8L, I chose the 422s based on your helpful evaluation and Costco's $100 off on tires and installation at the time. Thanks for your expertise.
    F8L likes this.
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I don't know about expertise but glad I could help, my friend. :)
    Merkey likes this.
  10. woodenpaddler
    17
    Maine
    I ended up replacing the new Bridgestone Ecopias on my 2008 Prius Touring with Yokohama Avid Envigors, same spec size for the Touring. The tire shop replace them under warranty at no cost to me. The steering is much improved, no more wiggle on the highway even with cross winds. So far the mpg hasn't changed; I got 44.1 mpg after 5 tanks, including a 12000 mile highway trip at 75 mph. The Yokohamas may not wear as well according to other reports, but handle better.
  11. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    12,000 miles + on 5 tanks works out a lot better than 44.1 mpg. According to my maths that works out at 2400 miles per tank.
    John (Britprius)
  12. woodenpaddler
    17
    Maine
    Clarification: 1,776 miles with 40.3 gallons; 1,200 miles of that was long distance highway driving.
  13. jeep2prius
    jeep2prius Reformed Jeepster
    17
    Los Angeles
    I put a set of those Ecopia(s) on my 2007 Prius and I've been happy with them. The mileage improved about 1-2 mpg and the noise level dropped a lot from the OEM models. I'm in Southern California, so haven't driven them in snow, but they handle okay in rain and on wet roads.
    9/22/2015:
    Been a while since I was online here, but wanted to give an update on these tires. After 4 1/2 years and 45,000 miles, the Ecopia are done. As I noted before, they were quieter and gave better mpg than the originals, but the handling got worse as they aged--a general wavering and 'squirreliness' in both city driving and at highway speeds. I'm also disappointed with their lifespan; tires on my Jeeps lasted 60-70,000 miles and those were heavier vehicles driven harder over rougher roads (and non-roads.) That said, the Ecopias handled surprisingly well on wet pavement and the few times I had to stop short or swerve hard.
    I'm not certain what I'll replace these with, but I'm looking for some model that's stiffer and less expensive. Any suggestions?
    #33 jeep2prius, May 24, 2013
    Merkey likes this.
  14. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    Compared to the OEM Goodyears, these get far better mileage and are softer/less noisy. I can't compare them with energysavers since I've never had them, but at $200 less for a set I can't really justify getting the Michelins for my DD. They wandered for the first thousand or so miles, but now either they've broken in, or I've just gotten used to it. One thing I really like about them is that they seem to give a lot of warning when they start to loose traction.
    Merkey likes this.
  15. woodenpaddler
    17
    Maine
    Updated: One year and 22,000 miles later the Yokohama Avid Envigors on my 2008 Prius Touring are worn down and need replacement to pass inspection. These tires make the car handle great but sure don't wear well.
  16. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    I've used EP422s for the last two tire changes and will use them as long as they exist. I'm not sure where the bad handling comments are coming from. These are a huge improvement over stock. I'm an aggressive driver and will activate the nanny frequently going around corners. The suspension, even though stiffer than stock, has far lower limits than the traction limits on these tires.
    They are quiet, get the same fuel economy as the OE tires, and last forever. We got 60K on the last set. The sidewalls are still a lot stiffer than a non LRR tire, so I'm not sure where the softer sidewall comparison comes from unless it's comparing to original rattle your teeth out of your skull tires that were slicker than ice and louder than a hurricane.
    krmcg and Merkey like this.
