Hands Free / Bluetooth dropping my calls?
Discussion in 'Prius v Audio and Electronics' started by Ihave2fundogs, Apr 4, 2012.
  1. Ihave2fundogs
    Ihave2fundogs New Member
    SC
    I have a Samsung Galaxy Nexus. I have it paired with the Prius V. This never fails, my calls get dropped after about a minute or a little more. I have to redial, then it happens again. Can anyone tell me why?
  2. Keiichi
    Keiichi Active Member
    808
    79
    Goleta
    May want to check your phone signal in the car, preferably while parked. Could also be your provider. Mind you, be sure to check the signal AFTER the connection is made, there is a likely chance the signal is weaker and may be the reason the call disconnects.
  3. Ihave2fundogs
    SC
    I never had dropped calls before?? All of a sudden, when I am talking on the hands free, it just cuts out. LIke it is timing out or something. My signal i s fine. I do check it.
  4. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    Try turning Wifi off. Sometimes the phone doing a search for a Wifi network will interrupt other functionality. It took an iPhone software update to fix it for Ford Synch. The problem was in the sending unit, the phone, not the receiver, the Ford. Likely true in this case also.
  5. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    why use wi-fi?? he has an LTE phone with data access faster than 90% of the public wi fi stations out there. it can do simultaneous voice/data connections. no reason to turn it on. just a waste of battery
  6. Keiichi
    808
    79
    Goleta
    Because some people forget to turn off their WiFi when they hop into a car, some places might be using some serious WiFi or using Hotspotting phones nearby that could cause it to trigger it to.
  7. Ihave2fundogs
    SC
    Thanks for the replies everyone. I should add that I have TMobile and the phone is unlocked. No LTE. I will try turning off the wi-fi next time, but I am pretty certain that it is not on 90% of the time.
  8. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    ooops! just re read your post. assumed you had the Nexus TWO... let us know how it goes
  9. Selborne
    Selborne Junior Member
    NYC
    I have the Samsung Galaxy Nexus (verizon) with the Prius v and calls never get dropped.
