Harbor Freight 24" Jack in Action
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rebound, Oct 29, 2016.
  1. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    IMG_7237.JPG I replaced my small Sears POS floorjack with a professional floorjack, and it is much better for car work.
    Here's my Harbor Freight Daytona jack lifting the front of my Prius for the easiest oil change I've ever done. I added several items to give an idea of scale. The bumper was up two full feet, and this is about how much room you have under the car after you lower onto jackstands.
    This jack cost $179 after a coupon. They have some for $129, and any good jack with 23" of lift is probably just as good for a Prius. The downside to this jack is that it's big and strong enough to life a small truck, so it's overkill for a Prius. It weighs about 100 pounds and you don't want to stub a toe on it.
    The positives are great: It is really easy to lift your Prius with this jack! Effortless to raise and lower. And, even better, having your Prius lifted this high makes it much easier to get underneath and work on the vehicle. I keep my garage fairly clean and I have an old yoga mat that I lay on under the car, which is pretty comfortable when working beneath.
    Before this jack, if I was working underneath and I needed to grab a tool or position a light, it was a real pain. And I couldn't always maneuver torque wrenches or breaker bars underneath very easily. That's no longer a problem.
    This jack in particular is very heavy duty and built for daily use in a garage. It has a beefy hydraulic pump which is easily serviceable, as well as many oil lube fittings for maintenance. I don't expect to need that for many years. Lifting and lowering are very smooth operations. Unlike my old jack, with this one, I just twist the jack handle to open or lower the valve for raising and lowering. When I release for lowering, it's very smooth and well-controlled.
    I've always been a tool snob; I hate cheap tools. I always avoided Harbor Freight, and I won't buy all of their stuff, but this Daytona floor jack is excellent quality and if you have room and the money, it will make your car work much more pleasurable.
    m.wynn, Raytheeagle, mracko and 2 others like this.
  2. JC91006
    16,936
    8,647
    Wish I had one
  3. Mendel Leisk
    42,345
    Looks good. (y) Looks like you've got the jackstands on those underbody rails, nice and solid.
    I'd rather do this than ramps. The latter may seem convenient, but in an enclosed garage, too much excitement.
    My pref. too, is to push a squat/wide tree trunk section under there, just aft of the engine bay undershield zone. Sometimes I don't, but it's cheap insurance.
    Rebound likes this.
  4. ChapmanF
    19,020
    Sigh. My easiest oil changes still have to be in my Gen 1 Prius: reach under car, loosen drain plug. Reach under car, remove filter. Reach under car, install new filter, tighten drain plug. Drive away.
    I miss that car.
    -Chap
    Robert Holt likes this.
  5. hrulia
    hrulia New Member
    US
    Rhino ramps work too .They cheap but you can't replace tire.
    Rebound likes this.
  6. Rebound
    3,996
    2,645
    Portland, OR
    I have Rhino Ramps, too. They're ok if I have someone to stand in front of them to make sure I'm going up properly. But you can't rotate tires or do brakes with the ramps, and they take up a lot of space in the garage. You wind up needing both the ramps and a jack, so having just the jack (and stands) makes more sense.
  7. Mendel Leisk
    42,345
    Think I've a little less: this is at full lift, it would settle some when seated on safety stands. Makes it roomy under there.
  8. Rebound
    3,996
    2,645
    Portland, OR
    I put those stands right where you showed me. :)
    Your jack lifts just about as high as mine. I did see several less expensive models that go just as high, but that yellow color... I think my Daytona is for lifting much heavier cars. It's a little overkill, but the old Sears POS needed replacing and this jack should last the rest of my life.
    #8 Rebound, Oct 29, 2016
  9. Montgomery
    Montgomery Senior Member
    2,254
    2,242
    Orange County, CA
    I live off of Harbor Freight. Got my tool box there and all my tools. Anytime a tool broke, took it back and got it replaced no problem. I have a ton and a half jack. Going for the 3 ton next time due to the stronger lift. Can you do me a favor? Can you photograph the spot in the center of the car that you lift the car against? For the life of me I couldn't find it and I lift from the sides using a wood plank (see attached photo). Oil changes I use the rhino ramps.
    Raytheeagle likes this.
  10. Rebound
    3,996
    2,645
    Portland, OR
    The jack points are in the manual. The front one is very easy to find, close to the front. I'm using it in the photo at the top of this thread. The rear is like a piece of plastic towards the passenger side, not right in the center.
  11. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    Reminds me time to change oil, should do it today too last 80F day
    Rebound likes this.
  12. Rebound
    3,996
    2,645
    Portland, OR
    I could change oil on my BMW without getting underneath, either. And I could pull the oil filter from under the hood.
    But there's more than just oil changes.
  13. Mendel Leisk
    42,345
    I'll just raise it up and crawl under there some days. :whistle:
    Rebound and Raytheeagle like this.
  14. Rebound
    3,996
    2,645
    Portland, OR
    For a long time now, one of the plastic rivets which holds the oil change apron to the car was broken off. I tried to yank it off with pliers, without any luck. But when underneath the car yesterday, I got a punch and chisel and finally knocked the thing loose, so I could finally put the apron back on right. It's things like this that are better when you can lift the car up high and work on it.
  15. CR94
    CR94 Senior Member
    2,830
    1,242
    Northwestern S.C.
    That was also true of my Mazda GLC; no need to crawl on the ground at all. Prius is the opposite extreme.
  16. Mendel Leisk
    42,345
    I use a 3 pronged arsenal to remove those fasteners, each one is utile:
    A small flat-blade screwdriver is simplest way to start lifting center tab, in some instances.
    Most useful though is a paint can opener, basically a flat-blade screwdriver with a short 90 deg hook at the tip. This is especially effective in close quarters, say when the fastener's recessed in a pocket, hard to reach with screw driver.
    Finally, a conventional trim tool, designed to slip under both sides of fasteners and lift. This is especially effective on fasteners that are jamming, is most gentle on the cap since it's on both sides.
    Also, whenever the fasteners are removed, I sluice them out with hot soapy water, get the grit out. That helps immeasurably in making them last.
    WilDavis likes this.
  17. Rebound
    3,996
    2,645
    Portland, OR
    The tiny screwdriver works great for me. But I had one fastener (a larger one) which had snapped off from a careless mechanic at the dealer. There was just a plastic stub jammed in the metal. I had to bang on it with a hammer and a punch to get it out.
    #17 Rebound, Nov 9, 2016
  18. Mendel Leisk
    42,345
    Yeah those things are expensive, typically around $5 up here. You can find cheap generic, but it can be frustrating: there's different diameters and depths needed, and quality control on the generic is iffy. This attachment has the part no's.
  19. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    I was at harbor freight recently and that yellow jack was tempting....
    While doing my oil change yesterday, snapped a shot of the height on my setup. This is with a 10 year old 3 ton harbor freight jack:
    At full extension ( about 23 inches):
    With jack removed and at rest (about 17 inches):
    Definitely enough room to get under there with a low profile creeper, another harbor freight buy;).
    Great suggestion for a jack @Rebound !!
  20. Mendel Leisk
    42,345
    Plenty of lift with that.
    As John Candy would say: "It's not pretty, but it gets us where we want go".
