Hard Driving in Prius
Discussion in 'Gen 3 Prius Main Forum' started by Almost_There92, Jul 25, 2015.
  1. Almost_There92
    Almost_There92 New Member
    Mississippi Gulf Coast
    So for reason irrelevant, at about 500 miles on the odometer, I drove the Prius quite hard the past couple of days. In retrospect, a poor decision as I am now all kinds of concerned as to what kind of damage I may have done. I know break-in is said to be 600 miles so I was below that. I'll describe my 'hard' driving as heavy acceleration, often pedal to the floor, a few hard stops and umm excessive speed (we'll leave that up to interpretation). So I'm just stressing about it now. Thoughts?
  2. Mendel Leisk
    42,211
    Probably nothing significant, they're not that fragile. But yeah, best to take it easy on a new engine. And any time, both for engine longevity and mpg.
    Why do I feel like I'm listening to confession? :ROFLMAO:
    Almost_There92 likes this.
  3. Almost_There92
    Because of the guilt I feel as I was writing that post haha
  4. JC91006
    16,928
    8,637
    Some have argued it's good to "seat" the engine with a little hard driving.
  5. Almost_There92
    Yeah, I've looked at it that way..... I feel I drove it a BIT harder than someone who was intending on 'seating' the engine....
  6. JC91006
    16,928
    8,637
    at 500 miles, as long as your engine was warmed up, I don't think anything bad can happen. 500 miles is already a good amount of break in
  7. bisco
    52,731
    i don't think hard driving is good for any car at any age. it can't do anything but cause faster wear at the very least. maybe rethink the future and stop worrying about what you can't change. all the best.(y)
    matt b. likes this.
  8. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Are we gonna be seeing a Prius on a future episode of "cops"???
    Haha! :ROFLMAO::whistle:
    matt b. likes this.
  9. milkman44
    milkman44 Active Member
    591
    386
    Ky
    Your contrition is apparent, you are absolved, now for your penance, give it a good wash and wax and promise to refrain from further thrashing of you beloved Prius.:ROFLMAO:
    matt b. likes this.
  10. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    In high school I worked part-time at a diesel shop that specialized in detroit diesel stationary power plants for the oilfield industry. These are two-stroke OHC 4 valve turbo or supercharged (in some cases both) behemoths. After the initial warmup on a total rebuild, the chief mechanic would immediately perform full power runs. That was the break in.
    This engine builder does the same thing: Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power
  11. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Before we had "micro-machining", break-in performed the job of getting the parts to mesh tightly together without wear. These days that requirement is very limited. The main reason you had to take it easy on a new engine was the "micro-machining" generates a lot of very localized heat. So much it could change the metal, making it either very hard (so it could chip) or very soft (so it would wear much faster). As that is no longer required due to the "micro-machining" done at the factory, only a few things need to be "broken in". Things like the brakes. By 500 mi. most of that is done. In fact, as I recall, the manual advises to (and I'm paraphrasing here) momentarily load the systems heavily, with breaks in between.
    I doubt very much you caused any future problems. Hope you had fun, and don't show up on any photo-radar images. ;)
  12. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Your guilt is so extreme, and your regret at the actions so complete, I would ask why did you do it?
    You don't have to answer, but I don't think the reason is irrelevant. I think it's primary, if personal and hidden.
    That was about a 100 miles of pretty specifically defined driving style. Hardly accidental.
  13. Almost_There92
    Hahaha I greatly appreciate all the feedback from you guys! Both relieving and entertaining :)
    I also consider that the engine redlines at like 4500 rpm, I've had plenty of cars that I had to rev that high to get any kind of power out of it anyway......But the technology in the Prius is anything but conventional and so spinning the engine at that speed could still do damage; what do I know?
  14. bisco
    52,731
    as much as most of the rest of us.;)
  15. Blizzard_Persona
    1,787
    948
    Pa.
    2023 Prius Prime
    XSE
    Plus with the transmission being a CVT (constantly VARIABLE transmission) one would assume that even driving the car hard the load on the engine is constantly changing. I think the main thing in initial break in is not to maintain a set speed/ rpm for any significant amount of time so I've been told and heard over and over. With a cvt as stated the Rpm's are always changing thus I assume making break in a moot point? Just driving the car in no special way should break it in just fine I would think.
  16. zzrguy
    zzrguy Junior Member
    88
    23
    ny
    As long as you weren't flogging it and throwing threw the chicanes you should be fine
