Hard to insert charging nozzle into charging port
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Valencia Orange, Jun 1, 2015.
  1. Valencia Orange
    192
    81
    Valencia, CA
    2013 Prius Plug-in
    It is getting hard to insert the electric charging nozzle into the car's charging port. It use to be very easy to insert. The gray latch on the charging nozzle would lock into place immediately. I am not having to lift the charging nozzle while it is inserted, in order to get the gray tab to lock. Suggestions and help would be appreciated.
    Is the charging cable covered under the 36 month warranty?
    Thank you
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  3. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    IIRC, some have removed an O ring to make the connection easier?
    52,912
    sounds right. look down the charger head and see if the rubber gasket at the bottom is dislodged.
  5. SLOW_RR
    SLOW_RR Member
    155
    84
    Finger Lakes Region of NYS
    What bisco said! Remove the little (mine was red) "O" ring down in there with a pair of needle nosed pliers (probably a good idea to unplug the cord first from the outlet...) and just remove it. Bet it solves the problem. It did for me.
  6. seek
    seek Junior Member
    32
    Tewksbury, MA
    I had to push the rubber ring back down in a public charger. I probably should have used something other than the flat blade of a Swiss Army knife.
  7. hill
    9,042
    I pulled our o ring out ... lubed it up with silicon spray ... reinstalled. good as new. It does serve a purpose ... keeps water out if you're charging in a heavy rain.
    rxlawdude likes this.
  8. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Gasoline works wonders
  9. Andyprius1
    2,327
    859
    Cool CA
    Vasoline that is. Foiled by spell check
  10. rxlawdude
    rxlawdude Active Member
    701
    220
    So Calif
    2015 Tesla Model S
    Indeed, it's not like Toyota thought, "what can we do to peeve PiP drivers using our EVSE?" :)
  11. hill
    9,042
    Hey !!!! that's a good idea !!!
    oh ... vasoline . . . Great . . . . NOW you tell me
    :p
    #11 hill, Jun 11, 2015
    mrlebop and xliderider like this.
  12. bisco
    52,912
    any luck at the dealer?
  13. Andyprius1
    2,327
    859
    Cool CA
    No, dealer was out of vasoline.
    mrlebop and roflwaffle like this.
  14. bisco
    52,912
    should have checked the k-y inventory.
    mrlebop likes this.
  15. SLOW_RR
    SLOW_RR Member
    155
    84
    Maybe if you are charging in a flash flood..... I have charged in torrential downpours and never had any moisture get into the charge port. Take a good look at the angle the plug goes into the port on the car and tell me how heavy the flooding would have to be to get any water into the plug. I removed the dang "O" ring over a year ago. I can't see that it serves any useful purpose except to tick off owners... LOL Just remove it and forget about it.
  16. xliderider
    8,140
    3,280
    Honolulu, HI
    Lol, yep, walk up to parts counter at dealer.
    "I'd like to buy some KY please."
    mrlebop likes this.
  17. bisco
    52,912
    because my plug won't go all the way into the socket.;)
    mrlebop likes this.
  18. Andyprius1
    2,327
    859
    Cool CA
    It's just a question the plastic/hard rubber getting dry and grabbing a bii. Smear a thin amount of vasoline on the mating surfaces. NOT into the electrical openings.
    mrlebop likes this.
  19. xliderider
    8,140
    3,280
    Honolulu, HI
    Is Vaseline safe for the O ring material though? Water based or silicone grease might be safer.
  20. bisco
    52,912
    my aftermarket L2 didn't come with an o ring, just plastic on plastic. there must be a lube made for plastic?
