Hardwire Dashcam w/ Fuse Tap Troubles
Discussion in 'Prime Main Forum (2017-2022)' started by isw845, Feb 8, 2021.
  1. isw845
    isw845 New Member
    Los Angeles
    2020 Prius Prime
    Hi everyone,
    Just got a 2021 Prius Prime LE, has anyone had issues w/ hard wiring into the driver side fuse box? I have done this install countless times for other vehicles but I'm having such darn luck with this Prius.
    I found the 5A ACC fuse which I wanted to tap into, but it doesn't power the dashcam. Groundwire is grounded to one of the bolts nearby. When I pull the fuse-tap with the 5A fuse out of the location, the radio turns off, so I know it's making contact.
    I thought it might have been the hardwire kit's module being defective, so I bought a new one and soldered it to bypass the banana plug. Still - no power, but when I pull the fuse the radio turns off. Is there something I'm missing?
    Thank you!
  2. citiprius
    citiprius Active Member
    241
    236
    51
    2018 Prius Prime
    Donttjudgemee likes this.
  3. road2cycle
    road2cycle Active Member
    168
    108
    Sonoma County, CA
    Is the surface that the ground wire is connected to painted? If it is you’re not going to make an electrical connection to chassis (battery negative) for the ground wire.
    Have you verified the fuse for the dash cam is good (continuity check; not eyeball check)?
    Have you measured voltage between the fuse tap “output” and chassis?
  4. tchan2700
    tchan2700 Junior Member
    30
    I just did this yesterday. I had the exact same issue you had so I found an unused fuse spot and use that for the ACC+ wire. i used the hazard fuse for the BATT wire.
  5. chickenhawk
    chickenhawk Member
    261
    95
    CA
    On my other cars I just tap off the wire going to the dome light as the power is cut off once ignition is off. I will probably do the same on the Prime.
  6. chickenhawk
    chickenhawk Member
    261
    95
    CA
    Correction on my previous post. I actually had tapped off the power that goes to the homelink mirror as that one is switched power source.
    I just recently installed VIOFO A129 Pro Duo, for the switched power I tapped off the Lane Departure Sensor and the constant power I tapped off the dome light. I used 3 wire hardwire parking kit for the camera.
  7. Wills Prime
    Wills Prime New Member
    Which one is the dome light fuse?
