Hardwired Dashcam to HomeLink Mirror
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Boston Jim, May 15, 2015.
  1. Frederickdawg
    Frederickdawg Active Member
    596
    335
    Florida Unfortunately
    What sort do you have. ?
    SM-G935T ?
  2. My1stprius13
    My1stprius13 New Member
    Alabama
    Maybe this will help someone else since I've learned a lot from this group about my Prius.
    I couldn't find a direct answer to my situation.
    So I will post it now.
    I used a direct wire from Amazon that reduced 12v to 5v.
    I wanted to hardwire my dashcam to the homelink mirror. I wanted my dashcam to turn on when I started the car, and turn off when I turned the car off.
    I put the red (hot) wire into the beige wire, and the black (ground) wire into the black and white ground wire.
    It works perfectly for what I want.
    There were only 3 wires in my mirror. Red, tan/beige, and black and white.
    When I plugged the hot wire into the red wired harness, and the ground wire into the beige, or the black and white wired harness, my dashcam stayed on all the time.
    #22 My1stprius13, Jan 15, 2020
  3. My1stprius13
    Alabama
    My last post is incorrect. It seemed to work yesterday, but not today.
    I will work on it some more, and report back.
  4. My1stprius13
    Alabama
    I'm so stupid. It does work putting the wires in like I said. The negative wire popped out is why it stopped working.
    I apologize for the repetitive posts.
    I will be more careful about when I post something in the future.
    I have a 2013 Prius by the way.
    elementnomore likes this.
