HARNESSING PRIUS ALTERNATING CURRENTS
Discussion in 'Gen 2 Prius Technical Discussion' started by Dxta, Oct 1, 2017.
  1. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    Yeah, have checked em, and I think he's stuff is cool.
    I have being intimated with lots of options, one, that I think would be cool, uys hooking up my inverter to the auxiliary battery, and readying the car.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Oh I see your modifying the ups to use the g2 battery in place of the ups battery. That would probably work.
    I wonder how much that ups costs. Probably very expensive.
    It was the TECHTREK threads back in the day that got me started on this.
    MTL_hihy likes this.
  3. edthefox5
    10,096
    4,840
    Clearwater, Florida
    The absolute power you can get from our battery pack is 3 amps? Lol......
  4. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    You know better than that!
    3A "....you *might* get two hours of run time"
  5. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
    Yes those UPS are expensive now but there's a big market for used ones so usually you can pick one up for just a few hundred bucks but plan on replacing the batteries right away because typically they are toast.
    edthefox5 likes this.
  6. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Great idea thank you. I looked at them brand new the 2200 va was like $1200.
    As someone who recently spent 6 days on a generator after hurricane Irma I was desperate for an alternative. I was using a gas only generator but after Irma bought a flex fuel. To have a backup using my car would be awesome thanks for the post.
  7. MTL_hihy
    536
    261
    Maritimes, Canada
    Key is to stick to 192V (battery) and single phase systems, after that there's typically quite a few options available all the way up to around 6 kva backup systems. Larger than that and they add more battery packs (192V x 2 = 384V) which don't work with the Prius setup (voltage is too high on UPS battery).
    Here's an example (obviously needs batteries too):
    Emerson Liebert Upstation S 6 kVA UPS backup, single phase | eBay
    There are better deals out there as long as you are patient and know what you're looking for.
    Dxta and edthefox5 like this.
  8. Ryambo8713
    Ryambo8713 New Member
    Temple city
    2014 Prius Plug-in
    do you guys have a list of recommended UPS to use for a Prius plug-in? I’m interested in making my 2014 PIP a backup generator via HV battery.
    iPhone ?
  9. Ryambo8713
    Temple city
    2014 Prius Plug-in
  10. Ryambo8713
    Temple city
    2014 Prius Plug-in
  11. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I think the Prius inverter is 3phase or so? Can't remember right now. Don't know if that would work though.
  12. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I think if you're going to use this inverter, it means you've to be careful accessing the HV battery. I won't try using that one the car though, except there are aftermarket harnesses to use with it.
    The inverters I know of are connected straight to the auxiliary 12V battery, when the car is readied. That would inverter the DC voltage to either a 110/220V AC voltage supply.
  13. edthefox5
    10,096
    4,840
    Clearwater, Florida
    Thanks for those keep them coming. The Prius battery maxes at approx 240 volts dc but most likely under high load with an auxiliary Inverter on it would live at around 210 volts dc at high load maybe lower. Thats an odd inverter dc input voltage making it difficult to find the precise Inverter. I personally would not need more than 30amps @117V for a wall shaker ac and the frig and some lights. I would not use 240 as i have no intentions of using any 240 volt device. Just a 117V ac wall shaker and the frig and some lights is what i had for days with my gas gen during Irma but man it ate alot of gas. I bought a flex fuel gen that runs really nice on propane that outputs that and have about 15 20lb tanks so far.
    But one issue is I suspect that our hybrid battery would have to be in really good shape for a long hurricane Inverter session. Mine has been rejuvenated by a Prolong and running very well but I don't think it would be happy with that extra constant 40 amp Inverter load on it. The car/mg's Inverter etc would support it fine I think but my 11 year old battery would probably let me down after a few days. With a new hybrid battery I am convinced it would be the ultimate emergency generator with the proper aux Inverter. It could run forever with enough fuel. Its the toughest little car ever made.
    #33 edthefox5, Feb 9, 2018
