Harry's unscientific ECO-Normal-Power-Lucas additive test runs
Discussion in 'Gen 3 Prius Fuel Economy' started by harrysprius, Aug 4, 2017.
  1. harrysprius
    harrysprius Active Member
    277
    126
    Nashville, TN
    OK, so after much back and forth I'm going to do a four week test run as follows.
    Week 1- Eco mode
    Week 2- Normal mode
    Week 3-Power mode
    Week 4- Whatever mode I end up using with Lucas fuel treatment added.
    I'll start each week with a fill up at the same station and try and use the same pump. I'll set tire pressure on Monday morning as well, and I'll set the cruise at the same speed each day. Week 4 will be with the Lucas in whatever mode I end up choosing, which will probably be normal.
    For info, My commute is about 1 mile to the interstate, 53.5 miles of highway, and a couple blocks of city to our parking garage. Ends up being 110 miles a day, so I'll have to fill up again once during the week. I'll do it on the same day each week. I just changed the air filter last week and the oil is mobil synthetic hybrid with about 5k on it. The tires are not LRR, but I'm not changing them until they wear out. Does anyone want me to modify or add anything to the test? I'll put the results up and I'll add heat and ac use for reference, and I won't drive it for anything else for the test period other than driving on the weekend.
    Aaron Vitolins and RMB like this.
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Another week of.eco at the end once the weather is cooler will give it a chance.
  3. harrysprius
    277
    126
    Nashville, TN
    No problem Jim. Do you want me to do it before or after I go to the Lucas?
  4. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    As late as possible I get too hot In summer in eco, which mean my batteries do to.
  5. harrysprius
    277
    126
    Nashville, TN
    I may do the lower grille blocking as well.
  6. harrysprius
    277
    126
    Nashville, TN
    How often should I update this? Daily, weekly, at the end only?
  7. Tideland Prius
    16,683
    weekly or at the end, whichever you prefer :) (do you want to keep us in suspense? Do you need to time pore over the data before publishing?)
  8. harrysprius
    277
    126
    Nashville, TN
    I'm tempted to just put it up daily so I don't loose any data....
    Right now I'm taking a picture of the dash at the end of every trip, and I might forget. And my kids already got a small side trip in, had to go pick them up from the rec center last night!
  9. harrysprius
    277
    126
    Nashville, TN
    OK, new plan.
    Week four will be grill blocking. Week five will be with Lucas fuel treatment at 4 oz per tank. That will give the car a little more time without it before the run with it. I'll probably do that run in normal, but if eco actually beats normal by a bunch, I'll run it in eco. If it doesn't, then it'll be in normal. Anyone want any other runs in?
  10. RMB
    RMB Senior Member
    406
    642
    Oakland, CA
    I an just wondering why do grill blocking during summer time?
  11. Tideland Prius
    16,683
    How cold is it in TN this week?!?
    You're fine if it's above 50°F.
  12. harrysprius
    277
    126
    Nashville, TN
    Grill blocking is supposed to give you a bit better MPG. I think there are two arguments about how, one is just better air flow efficiency, the other is that the car warms up faster. I just figured I'd try it out and see what happens.
  13. harrysprius
    277
    126
    Nashville, TN
    Its been about 65-70 most mornings and 80-85 on my way home.
  14. Mendel Leisk
    42,369
    I'd recommend block heater use (a couple of hours before first cold start of the day) over grill block. But that's not a trivial undertaking. The part is between $50 and $100, but the install is not fun, and install prices through dealership run around $300?
    Blocking the lower grill (50%, 100%?) in summer could be risky. Per other posters, I'd reserve it for ambient temps below 50F. Also, if you're doing some sort of sustained uphill climb (going up a ski hill for example), I wouldn't use ANY grill block, regardless of ambient temperatures.
    Also, it would be good to monitor engine coolant temps when doing this; don't just jump in.
    Also, be very careful if you block upper grill: never block it 100%, since it has inverter radiator in that area. Do 50% at the most, in extreme cold. Tennessee, forget about it.
    Good thread on grill block:
    2010 Prius Grill Blocking strategy | PriusChat
    Montgomery likes this.
  15. harrysprius
    277
    126
    Nashville, TN
    Maybe I'll just skip the grill blocking, at least until I get a scan guage or moniter. Ill try the Bluetooth one I have and see if it'll work.
    Not going to do a block heater. Looks like way to much hassle.
  16. Tideland Prius
    16,683
    But you're just plugging/unpluggng like an EV ;) haha.
    Yeah I agree, an EBH will give you better results than grille blocking because of summer temps. But honestly, those temp ranges you gave, neither EBH or grille blocking will give noticeable benefits as you're already in the temperature sweet spot.
  17. harrysprius
    277
    126
    Nashville, TN
    I really thought that the logic was air flow, or drag. Most of the hypermilers block everything they can.
  18. harrysprius
    277
    126
    Nashville, TN
    ECO-Filled tank Monday AM to start trip, BP at hwy
    Day 1. To work-Intermittent rain/wipers, 73deg., headlights on, defrost at the beginning, no heat or air, cruise set at 72 to NV, about 65 from belt way in, traffic light to medium. 52.9 miles, 47.3 mpg, 62 mph avg speed. To home- clear, no headlights, no heat or air, radio on, about 65-70 out of NV, cruise at 74 after, traffic medium, daily commute total-106.9 miles, 46.4 MPG, 62 mph
    Short trip to pick kids up from rec center- 113.2, 46.6 mpg, 58 mph
    Day 2. To work, 70 deg, headlights on, defrost at the beginning, no heat or air, cruise set at 73 to NV, then about 65 from beltway in, traffic light to medium. 53.8 miles, 44.2 mpg, 63 mph avg speed. To home-clear, 86 deg, no headlights, intermittent ac on low, cruise on 74 after NV, traffic medium to heavy, one 10-15 minute slow down from accident, daily commute total-107.9, 44.1 mpg, 50 mph
    Day 3. To work-65 deg, no headlights, defrost at beginning, no heat or air, cruise at 72 to Nashville, about 60 from beltway in, traffic light, 53.8 miles, 45.9 mpg, 62 mph. To home- clear, 85 deg, no headlights, intermittent ac on low, cruise on 74 after NV, traffic medium heavy, had to stop for gas on the way home, 113.2 miles, 46.6 mpg, 58 mph.
    Day 4. To work-64 deg, clear but wet-ish, headlights, defrost in the beginning, no heat or air, cruise at 72 to NV, then about 65 in, traffic light, 53.8 miles. 44.7 mpg, 62 mph. To home-86 deg, clear, no headlights, intermittent ac, medium heavy traffic, cruise on 74 after,107.9, 45.6,57mph
    Day 5-To work-65ish, clear, no headlights, defrost in the beginning, no heat or air, cruise at 72, then 65 in, traffic medium, 53.6 miles, 46.9mpg, 65mph. To home-78, clear, medium heavy traffic, intermittent ac, cruise on 74 after NV, 108 miles, 44.5 mpg, 53 mph.
  19. harrysprius
    277
    126
    Nashville, TN
    Summary
    Day 1-106.9 miles, 46.4 mpg, 62 mph
    Day 2-107.9 miles, 44.1 mpg, 50 mph
    Day 3-113.2 miles, 46.6 mpg, 58 mph
    Day 4-107.9 miles, 45.6 mpg, 57 mph
    Day 5-108.0 miles, 44.5 mpg, 53 mph
    543.9 miles, 45.44 mpg, 56 mph. NOTE. I did not weight the averages, it is a 5 day total avg only.
    Actual gas used was 12.42 gallons for a real world number of 43.79.
    RMB likes this.
  20. harrysprius
    277
    126
    Nashville, TN
    Week 2 summary coming tonight when I get home from work.
    Tideland Prius likes this.
