Harry's unscientific ECO-Normal-Power-Lucas additive test runs
Discussion in 'Gen 3 Prius Fuel Economy' started by harrysprius, Aug 4, 2017.
  1. harrysprius
    harrysprius Active Member
    277
    126
    Nashville, TN
    Week 2-Normal-Filled tank Monday AM to start trip-BP at hwy
    Day 1. To work-70deg, clear, headlights, defrost in the beginning, no heat or ac after, cruise at 72, then 65ish after, traffic light, 52.9 miles, 46.7 mpg, 65 mph. To home.-78deg, intermittent rain, heavy for second half, defrost on some second half, no heat or ac, light traffic, cruise on 74 after NV, 107.1 miles, 44.5 mpg, 61mph
    Day2-to work-68 deg, clear, headlights, defrost in the beginning, no heat or air, crusie at 72, 65ish after, traffic light, 53.8 miles, 46.2 mpg, 64 mph. To home-85 deg, clear, no headlights, ac intermittent, light traffic, cruise on 74 after, 108.1 miles, 45 mpg, 60 mph
    Day 3. To work, 68 deg, overcast, headlights, defrost in beginning, no heat or air, traffic really light-cruise on 72, then 65 ish, 53.8 miles, 46.6 mpg, 65 mph. To home, 80 ish, clear, little bit of ac, relatively light traffic after NV, then cruise on 74. 107.8 miles, 44.8 mpg, 59 mph. Filled up with gas on way home
    Day 4. To work, 72 deg, overcast, headlights, defrost in beginning, no heat or air, light traffic, cruise on 72, then 65ish, 53.8 miles, 46.6 mpg, 64 mph. to home- 85, clear, ac intermittent, light traffic after NV, heavy until out of, cruise on 74, 107.9 miles, 45.1 mpg, 58 mph
    Day 5. To work, 70 deg, no defrost heat or air, light traffic, cruise on 72, 65ish in from NV, 53.8 miles, 44.6 mpg, 64 mph. To home.-90 deg, medium traffic, intermittent a/c, cruise on 74. 108 miles, 45.2 mpg, 59 mph
    Tideland Prius likes this.
  2. harrysprius
    277
    126
    Nashville, TN
    Summary week 2- Normal mode
    Day 1-107.1 miles, 44.5 mpg, 61mph
    Day 2-108.1 miles, 45 mpg, 60 mph
    Day 3-107.8 miles, 44.8 mpg, 59 mph
    Day 4-107.9 miles, 45.1 mpg, 58 mph
    Day 5-108 miles, 45.2 mpg, 59 mph
    539.9 miles, 44.92 mpg, 59.4 mph
    Actual gas was 12.68 for real world number of 42.58.
  3. Tideland Prius
    16,559
    0.5mpg bump for 2-3mph reduction in average speed.
  4. harrysprius
    277
    126
    Nashville, TN
    I tried to keep my speed as much of a constant as possible, as I will for next weeks Power Mode. I did end up running a bit faster average MPH because I hit a bit different traffic patterns. I was about 15 minutes earlier going to work because I've extended my morning work out a bit longer and needed to leave earlier to give myself a few more minutes. Since I hit less traffic my speeds were a bit higher and more consistent, as in less "stop and go." Evenings were about the same. When the other ones are done I'll put all four weeks next to each other.
  5. harrysprius
    277
    126
    Nashville, TN
    Well poop.
    I got word that I don't have to drive to work Monday, I can work from home because of the heavy traffic expected from the eclipse. Do I do the week three Power mode test with just the four days, or do I just postpone it until next week?
    I am SO disappointed that I don't have to drive to work. ;););)
  6. harrysprius
    277
    126
    Nashville, TN
    No more poop.
    Got a set of tickets to the Titans game on Saturday. Might not be the exact same drive as going to work, but it'll be very close. Maybe a couple mile difference. That'll help make it closer to the first two weeks.
    Aaron Vitolins likes this.
  7. harrysprius
    277
    126
    Nashville, TN
    I keep seeing good reviews of Techron. Maybe add a trial of that next?
  8. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    How did i miss this whole thread??
    Did you end up going to the game? I got stuck leaving work in East Nashville Saturday. It was very frustrating!
  9. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    What have you set your tire psi to? Your gas milage seems sorta low. My Prius V gets the same if not better mileage. I run about 40 psi. I have 17" wheels
  10. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    I moved to franklin a few weeks ago! My commute yesterday form franklin to East Nashville I got 57 MPG. Traffic was ideal for Hybrid syenergy drive. Slow, but not too slow, still some EV driving, light braking, accelerating up to speed, slowing down, keeping the battery between 5 and 6 bars.
  11. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Once you get the injectors and fuel delivery path clean.........additional cleaning is just a waste of time and money.
  12. Sam Spade
    2,036
    1,023
    2017 Prius c
    How did you arrive at that figure ?
  13. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Via the onboard computer. In reality its 2-3 mpg optimistic unfortunately. So let's say 54 mpg. Not bad for a car rated in the low 40s. Most of the time for tank average I get about 46 47.
  14. harrysprius
    277
    126
    Nashville, TN
    Tickets are for this Saturday! Not sure how you missed it. My mileage sucks! I don't know why, but I know the tires are a part of it. Mine are not LRR. I'm going to try cleaning the intake, PCV ect.
  15. harrysprius
    277
    126
    Nashville, TN
    Were have you been Sam? You've been awfully quiet.
  16. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    It's got to be the tires. My pervious car was a 2012 Prius II. When I bought it, it had some cheap Chinese tire on it, I only got 44 mpg driving it home from Orlando with the cruise control. They got horrible milage! I couldn't stand it, so I bought 4 Energy Saver all season tires. Thoes tires were so damn quiet and so damn efficient especially after the tires were broken in. After that I drove to Cincinnati Ohio with the cruise control set to 70 and got 57 mpg the whole way up. I still can't even believe I got that good of milage. Incredible! I'll try to find a picture
  17. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    This was only the first 3 hours, the next two hours it was still getting over 57!
  18. harrysprius
    277
    126
    Nashville, TN
    I'm just having a hard time convincing myself to replace like new tires.....although it may pay for itself.
  19. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    Yeah it isnt the best move financially. I forgot, another reason I was able to convince my self to get new tires, the cheap Chinese tires I had were very loud too. Nothing like a nasty loud tire
  20. harrysprius
    277
    126
    Nashville, TN
    If these were I could use that excuse, but they actually ride and handle great. Others on here have told me that when I go to the LRR tire I'll loose some of that. Said they won't stop as well either. I guess that makes sense. If it doesn't stick to the road while your driving why would it when your braking?
