Harsh vibration
Discussion in 'Prius v Technical Discussion' started by cbydesign, Jul 12, 2018.
  1. cbydesign
    cbydesign Junior Member
    29
    Michigan
    I have a 2012 Prius V. Particularly when it was really cold this winter, but once recently, when I started the Prius, it rattled really hard. As in it sounded like it was breaking. Anyone had this happen? Not sure how to get someone to look at it as it has only happened something like 4 times and I can't make it just happen.
    I'd have posted this where more can see it, since they all share essentially the same drivetrain, but I didn't know where that would be.
    ~40k miles, second owner.
    #1 cbydesign, Jul 12, 2018
  2. Air_Boss
    Air_Boss Senior Member
    4,259
    1,197
    New Yawk
    We've had 'the rattle' happen once since we owned the 2012 v Five.
    A year or so into ownership, in the fall of 2012, I started the car to move it on the driveway, then shut it down. Upon restarting it a half hour later, it did 'the rattle.' I shut it down immediately. Started it again after a few minutes and it operated normally. Hasn't happened again.
    I have seen a variety of suggested causes, most relate to unburned/remainder fuel in the intake manifold. It doesn't worry me.
  3. cbydesign
    29
    Michigan
    Yeah, it goes away after a little bit of running. Just didn't know if there was a common cause. Searching gave me a pretty wide variety, as you said. One time, I used the remote start and thought something was going to blow up in my garage!
    52,849
    try not to shut it down during the warm up cycle until the engine has shut off. how many miles on her? around 100k, you want to start thinking about cleaning the intake manifold and egr circuit.
    cbydesign likes this.
  5. prevee5
    prevee5 Member
    122
    Monrovia, California
    Yep, mine does the same thing. Scares the heck out of me. Thought maybe a cat or squirrel was in the engine compartment.
    I have a 2012 model Five...appx 80000 miles. Happens about once every 6 months or so. Not sure what the cause is but it smooths out after about 10 seconds. Very weird. And of course, the dealer has never heard of this and cannot duplivcate the problem.
    But yes, the only commonality with others is that it does seem to happen after I move the car from one place on my driveway to another.
  6. bisco
    52,849
    unburned hydrocarbons in the intake manifold.
  7. S.Bell
    S.Bell Junior Member
    70
    Bay Area, CA
    2013 Prius v wagon
    Is y'all's gas mileage also effected?
  8. Leaderman
    Leaderman New Member
    Sf
    2014 Prius v wagon
    Three Touring
    you are in for a big surprise soon unless you take care of it ASAP. i.e. clean the egr system. you should only use the manufacture recommend engine oil type. Gen 3priuses are prone to localized engine over heating that will lead to head gasket issues. your coolant should not be low but when the problem exacerbates you will see low coolant with no leak it usually goes to cylinder one when that happens it will trip a code P0301 at this point if you are losing coolant just get head gasket test kit from amazon it will confirm a blown head gasket.
  9. bisco
    52,849
    head gasket repairman to the rescue!(y)
  10. ivfx
    ivfx Junior Member
    36
    Dhaka Bangladesh
    If it’s a regular occurrence stop wasting money and invest in a JDM engine $1200 or head gasket change/ rebuild. Check my Prost history
