Hartle-Hawking State
Discussion in 'Fred's House of Pancakes' started by bwilson4web, Mar 3, 2018.
  1. KennyGS
    KennyGS Senior Member
    1,243
    1,046
    Keystone State
    Our laws of physics are based on the limitations of our perception. I believe there are physical conditions in our universe that we are unable to sense.
    vvillovv and bisco like this.
  2. fuzzy1
    10,672
    That was known before Hawking was ever born.
    Both can happen, but they are not the only examples of electric currents. There are more, some of which can happen in a vacuum without any matter present.
  3. oli123
    oli123 New Member
    Washington
    Yes truly agreed with your opinion
  4. Mendel Leisk
    42,191
    Now how the heck does this happen:
    vvillovv likes this.
  5. Trollbait
    12,787
    Posts aren't counted in the off topics area.
  6. bisco
    52,692
    thanks, i thought it was because we were in a vacuum...
    AzWxGuy, vvillovv and Mendel Leisk like this.
  7. vvillovv
    vvillovv Senior Member
    4,336
    1,517
    NY
    looked like another j script hickup . I never suspected off topics aren't counted as posts. :cry:
    I'll never catch up to @bisco post count now.
    bisco and Mendel Leisk like this.
  8. kenmce
    kenmce High Voltage Member
    1,552
    525
    NY
    Back when they named "negative" and "positive" they thought something was coming from one side and going to the other but they had no way to measure it, so they guessed. Turns out they guessed wrong and the electrons come from the negative side, but by now nobody is going to change the names.
    Oops. :rolleyes:
  9. vvillovv
    4,336
    1,517
    NY
    batteries
    depends of which way your thinking about them too. ways .. charging or discharging ... At least I hope there are only two ways of travel .....
    I first thought about this when others would talk about IR (internal resistance) commonly, cause it made no sense to me from the charge side of the equation, as opposed to the discharge side of things, unless one read between the lines of what was being referred to. Still ? I hope someone has a better description than I do, cause I'm still :unsure::notworthy::confused:
  10. Mendel Leisk
    42,191
    I’ve always wondered about that. Maybe they explained in high school (took vocational, included electrical class) but I never twigged to that. I figured the opposite lol.
    So, the car body has a surplus of electrons, all itching to get to the positive terminal, how about that.
    Q & A: Which way do the electrons flow in a battery. | Department of Physics | University of Illinois at Urbana-Champaign.
  11. bisco
    52,692
    if you disconnect the 12v neg, and touch the pos to ground, nothing happens?
  12. Mendel Leisk
    42,191
    Shouldn't. You first though... :unsure:
  13. ChapmanF
    18,889
    In a metal wire, it's the electrons flowing. They carry negative charge. The carriers of positive charge (protons) are tightly stuck in the nuclei of atoms, and metals have their atoms arranged in a pretty fixed latticey structure, so the protons aren't really going anywhere. But the lattice structure makes it pretty easy for an electron to hop along through it (the electron is attracted to the nucleus in its atom, sure, but it's nearly equally attracted to the nucleus in the next atom over, so it's a very easy hop).
    That's just the story in metals though.
    When current flows through some other substances, like a liquid electrolyte in a battery, other things can happen. At the electrodes, a molecule might split up into an ion with a net positive charge and another ion with net negative charge, and both of those can drift through the liquid, in opposite directions.
    The conventional way we draw the arrow for "current flows this way" is it's the direction the positive ones are moving. The negative ones are drifting past those, moving the opposite way. The total current flow then is the sum of what positive carriers are doing (in the direction of their movement) plus what the negative carriers are doing (in the direction opposite their movement).
    So the situation in a metal is just the edge case of that, where the positive charges aren't going anywhere, so that term is zero in the total current, and the term for negative charges in the opposite direction is what makes up the whole total.
    bwilson4web likes this.
