Has anybody *added extra* interior hatch release switch? (Gen 2)
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Priusjames, May 14, 2021.
  1. Priusjames
    Priusjames Member
    91
    68
    Irvine, CA
    Has anybody added an interior release button...maybe by modifying a Dorman (or OEM) replacement switch like this one? I’m thinking about splicing into the existing switch wiring (in parallel) and routing it to the inside and cutting a hole in the interior hatch panel to mount the new switch so it can be accessed/pushed from inside the car.
    I’ve started upgrading my 2006 for camping/overlanding excitement and
    I *know* this issue is going to bug the crap out of me while I’m sleeping back there.
    I guess any old momentary contact button/switch could be used with a 12v wire (and a relay?) to inject power to activate the solenoid? There’s still the issue w the heavy hatch not just “popping open” and needing to be pushed up from inside...new hatch struts would help...but that’s just an inconvenience compared to NO INTERIOR OR FOB HATCH RELEASE! The only interior release is hidden under a bunch of stuff wedged in the nether-regions deep in an unmarked greasy grave(hole).
    The “No interior glow in the dark safety release like every other car in the world” thing has always bugged me, poignantly at times...especially the 1st time a 12v battery died in traffic! I’ve had a Gen 2 since 2003, so there have been several 12v battery deaths. I’m an old pro now, saved my uncle a TON of grief when he called me about his 1st recently acquired Prius 12v battery failure.
    A thread search only found people complaining/explaining the existing configuration, nothing about adding a new switch/button modification. It seems simple-ish...what am I missing? Any thoughts/ideas on what to use and where to put it?
    TIA - James
    52,923
    i vaguely recall someone doing something, but can't find it. i could be wrong, it definitely has not been done here enough to stand out.
    Priusjames likes this.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,100
    Columbia, SC
    I like your idea, especially if its just to have a way to open the rear hatch after taking a nap in the car. You could potentially just wire it up to the small trunk light switch or something similar, since it always has power available
    ydpplqbd and Priusjames like this.
  4. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    i always just crawl forward and pull the rear door handle... and then the alarm goes off and i fumble for my fob so i can stop it before someone calls the cops. (as if they'd show up any time soon...)
  5. Priusjames
    Priusjames Member
    91
    68
    Irvine, CA
    I've been removing old window tint for days, but am planning to get to this trunk/hatch release modification this weekend. Will take pics if I can with my fingers crossed at the same time.
    Sanchan likes this.
  6. ChapmanF
    19,072
    I almost did it for a friend with a 2010 ... got as far as identifying the circuit in the wiring diagram, went right through the junction connectors behind the driver's kick panel, would have been a short sweet run up to one of the blank switch positions on the left lower dash. But he moved west and decided a truck would be better.
    Not sure how well any of that translates to Gen 2 ... better to look in the wiring diagram for your model year directly.
  7. Priusjames
    Priusjames Member
    91
    68
    Irvine, CA
    It was easier than that for me...I had taken off the interior panels/covers inside the hatch and the plastic panel on the back that holds the existing exterior switch to get it all properly painted, so I had that section of wiring harness in my hand (literally!) when the thought of how easily it could be done struck me.
    I'm planning to mount the switch in the rear because I'm planning to sleep back there...also the reason that I'm finally getting around to doing something about it after owning one of these things since 2003. Heh.
  8. ChapmanF
    19,072
    That makes sense. My friend was driving Uber or Lyft and wanted a way to open the hatch for his passengers without getting out, hence a button on the dash would have been convenient.
  9. Priusjames
    Priusjames Member
    91
    68
    Irvine, CA
    Success! hatch_switch_before.jpg hatch_switch_after (1).jpg I ran to O-Reilly's and picked up the cheapest Momentary Contact switch they had. Spliced it into the wires between the existing switch and the rest of the loom. It works as intended.
    I will post a photo after I install the switch after I decide where that should be. Perhaps I can find a spot I can reach from both the driver's seat *and* when I'm crammed in the back. I'll have to think that through.
  10. bisco
    52,923
    well done!(y)
  11. Matt98svt
    Matt98svt Junior Member
    99
    South Carolina
    2015 Prius v wagon
    looks great! so where did you end up mounting the switch? do you have a photo? I just purchased a Prius V to camp in and been doing research on doing just this
  12. Another
    Another Senior Member
    1,819
    520
    Naples, Florida
    The best place IMHO to locate it would be in one of the blank switch plates on the dashboard next to the SKS defeat switch. That’s where Toyota should have put one in the first place. Saved Toyota a couple of dollars per car and causes immense irritation to millions of customers. A smart dealer or aftermarket shop would offer to install one for $150 for thirty minutes of shop time and probably sell out.
    ydpplqbd likes this.
  13. ChapmanF
    19,072
    Well, if you want it so you can easily open the hatch from a sleeping position in the rear, the dash might not be the ideal place. Toyota left it so you can configure to your liking. ;)
    RHennick and Priusjames like this.
  14. Another
    1,819
    520
    Naples, Florida
    Yeah, thanks, Toyota, so thoughtful.
  15. justlee
    justlee Junior Member
    23
    CA
    I added a mechanical release. I just tied a thin wire onto the small shiny lever on the bottom of latch and fed it almost straight up through a small hole I drilled through the plastic trim. Pull up on wire and hatch unlocks even if no battery!
    Gino Veltri, TBM and bisco like this.
  16. bisco
    52,923
    well done! pics please!
  17. Another
    1,819
    520
    Naples, Florida
    Yep, a photo or two would be great
  18. Another
    1,819
    520
    Naples, Florida
    May want to add this?
    https://www.quirkparts.com/oem-parts/ford-oem-new-ford-handle-assembly-1r8z-5446318-aa-1r8z5446318aa?origin=pla&gclid=Cj0KCQiAhf2MBhDNARIsAKXU5GR-FeT4gjwzeNbcfdQVZSeRtnqYkpyxlVfqhKIoWlNW3_4FrcEXpFcaAlBWEALw_wcB
  19. justlee
    23
    CA
  20. Another
    1,819
    520
    Naples, Florida
