Has anybody ever...
Discussion in 'Gen 2 Prius Accessories & Modifications' started by 2jzprius, Jul 21, 2008.
  1. dwdean
    dwdean Member
    377
    South Florida
    Honestly, I can't remember if he whined his way out all together or whether it was just out of solitary, but I'm couldn't agree more.
  2. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    Well, you know what they say....seeing is believing. I am waiting to see pictures of this project as it progresses. I remain optimistic but suspect you might just be a kid with a pipe dream who might be able to build a model car but not a real car. Maybe I am wrong?????
  3. biggus
    biggus Junior Member
    55
    Dublin Ireland
    It might be simpler to drape the prius body over the damaged Supra frame and running gear. Just alter the wheelbase to match to prius so it looks right. Guy in germany years ago put a widened Golt/rabbit body on a porsche 928 chassis and running gear.(early 80's type golf.)
  4. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Wasn't that Franco Sbarro? If anyone could turn a Prius into a supercar, it's him. He must have several spare flat 12s lying around. :p
  5. a_gray_prius
    2,927
    783
    IL
    I agree with Cairo. I really want to see this build.
    I hope you get something together 2jz, cause someone just put a K20a in an Insight. 200hp and it *still* gets 40+mpg with a full interior and intact A/C. They're running 40 degrees of advance at 19:1 afr at cruise. Insane.
    K20a INSIGHT by LHT - Tampa Racing
    It looks like LHT is getting a huge amount of publicity (try to google "k-sight") so if you get this done, you probably won't win (m)any pink slips (too many people already know hybrid swaps can be/are being done) but you'll certainly get quite a bit of attention.
  6. gooch
    gooch New Member
    Melbourne, Australia
    My last car was a Toyota Aristo that obviously comes with a 2jz and I had heavily modified it to have an Apexi RX-6 single turbo conversion. Was making 300rwkw's. I strongly advise against this because the engine will just require too much fabrication.
    What I suggest doing is looking towards 4g63t from an evo. You should be able to fit them under the hood of a prius although I imagine it will be quite tight. You will still smoke just about everyone and there are many off the shelf perfomance parts available.
  7. a_gray_prius
    2,927
    783
    IL
  8. gooch
    gooch New Member
    I would also love to see it but I'm not sure if it would actually fit. There's no tunnel down the centre of the car to fit a drivetrain through there so that will cause some issues. I suggest buying a really big shoe horn if you want to give it a shot :p
