Has anybody extended the cord from the charge controller?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Lorax1, Dec 18, 2015.
  1. Lorax1
    Lorax1 Junior Member
    2003 Prius
    I figured it would be better to lengthen the 1 foot 14 gage cord, than add on an extension cord. I made it past the tamper screws, but the waterproof cordlock has stopped me for the moment. 12' of 12/3 directly wired has to be better than 1' of 14/3 and an extension cord.
    Doug
    52,883
    welcome! nope. get a good extension cord. determine how many feet you need, and buy the appropriate gauge. don't use romex tables, as stranded wire needs a heavier gauge. 25' of 12 gauge should be fine. get a good quality, or the connections might heat up.
    there are plenty of threads here on extension cords. all the best!(y)
    priuskitty likes this.
  3. gallde
    gallde Active Member
    238
    131
    Tarrytown, NY
    I tried to remove that cord as well, needs a special tool nobody has. Just use an good quality extension cord, 14-ga if less than 20 feet, 12-ga if longer. I keep a couple 10-footers in my hatch storage bin.
    Andyprius1 and priuskitty like this.
  4. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I had to deliberately cut both my extension and my charge cord as they were wedged under the trunk edge. Have been operating for several months with both my sliced cords and have had no problems or hotspots. Should you venture to do this, get the proper size splice and heat shrink with a hot air gun for heat shrinking. And a good electricians tape wrap afterwards.
  5. Andyprius1
    2,327
    859
    Cool CA
    Probably the best solution.
