Has anyone adjusted their engine/transmission mounting points?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Priipriii, May 15, 2023.
Tags:
  1. Priipriii
    Priipriii Member
    231
    67
    I am looking to swap engines, but if im going to go that route, i might as well do a lift as well since I always wanted one on the prius.
    I want to move/cut/weld the mounting points lower. The whole purpose of doing this is to keep the driver side axle rod straight and not at a steep angle when lifted. Is this doable or am i over my head here?
  2. Leadfoot J. McCoalroller
    8,292
    7,808
    Pennsylvania
    2018 Prius c
    I'd think a couple extra axle joints over the life of the vehicle would be cheaper and less work than re-doing the mounts and potentially having to elongate several wire harnesses and coolant plumbing runs.
  3. black_jmyntrn
    black_jmyntrn Senior Member
    1,729
    411
    2013 Prius Plug-in
