Has anyone got better MPG with ethenol?
Discussion in 'Gen 2 Prius Fuel Economy' started by Walker1, May 27, 2008.
  1. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    This is an old story. Back in the early 90's, the gasoline was reformulated with MTBE to provided oxygenated gasoline. The MPG lost was about 10%.
    Then in the late 90's, the MTBE was replaced by ethanol due to contamination of ground water. The ethanol contributes to a 5% lost compare to 10% lost of MTBE, so there is a net gain of 5% since the switch. But it is still 5% less than pure gasoline.
  2. richard schumacher
    7,686
    1,068
    United States
    Be happy with the 10% ethanol blend (E10). It's an engine and injector cleaner.
  3. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    That's the only thing I was thinking too... unless the mpg payback of "no ethanol gas" is considerably above and beyond its increased cost, its definitely not worth it because if and when you get water in your tank... not only will there be no alcohol to disperse the water so it will pass without causing stuttering and/or all the other demons that come with having water in your gas, but the water can also cause rust and corrosion to have its way.
    Before ethanol came around.... we used to put alcohol in on purpose from time to time to remove any residual water.
    Go to the auto parts and buy the stuff that removes water and look at the ingredients... either they won't mention it at all "they're getting smarter!", or it will say isopropyl alcohol.... better known as "rubbing alcohol" found in your medicine cabinet!
