Has anyone installed a Carbon Fiber hood?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Goldmaniam, Feb 19, 2013.
  1. Goldmaniam
    Goldmaniam New Member
    I am wondering if anyone has a carbon fiber hood? Did you need to install hood pins? I have a black 2010 that has rock chips on the hood, and instead of repainting the hood, I am thinking about changing it to carbon fiber.
  2. xliderider
    xliderider Senior Member
    7,904
    3,136
    Honolulu, HI
    The hood is aluminum, so not much weight savings to be gained there. However, your wallet will be considerably lighter. :D
  3. mnml
    mnml Ain't nobody got time for that.
    377
    161
    Ladera Ranch, CA
    CF vinyl wrap would be much cheaper if your goal is to cover up the rock chips and have a CF look.
  4. Goldmaniam
    The hood is about $600 dollars, painting it is about 500. It says that hood pins are recommended, so that is my primary concern if it latches without the good pins
  5. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    I have a CF hood and I'm not using hood pins on mine.... never had a problem with it...
  6. Goldmaniam
    Where did you buy your hood from?
  7. Ragz
    Ragz Active Member
    210
    110
    New York
    I have had one for over a year, with no pins, no problems
  8. Goldmaniam
    Than I shall order one also. Does it come with the latch already attached? Do I need to assemble anything?
  9. Ragz
    Ragz Active Member
    210
    110
    New York
    The catch is there, but i had to move the prop bar and attatch the washer lines
    KLD_Prius_PI_Synergy likes this.
  10. bino
    bino JDM ZVW30
    1,348
    706
    SoCal 91739
    seibon..
  11. GasSaver1
    GasSaver1 Member
    220
    South Florida\Long Island NY
    what happens in a big front end crash? does the hood crumple or shoot back through the windshield?
    I was considering one of these but there may be a safety issue
  12. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    wow, their site is painfully slow. I wouldn't think about making a CF hood for the Prius for $660.
  13. Totmacher
    Totmacher Honey Badger don't give a carp
    301
    110
    Mission Viejo, CA
    Typically a standard carbon fiber hood is really just 1 layer of carbon fiber for looks and the rest is fiberglass. This makes them not much of a weight savings. In this case they will crumple up.
    Usually a full race Carbon Fiber hood that is majority carbon fiber is substantially lighter. But these do potentially cause a crash concern. I remember one vendor would not sell us an all out CF hood until we showed proof we had a full 10 point cage in the race car to protect the hood from cutting through the windshield. but this hood was about 5 times the cost of your typical CF hood.
