has anyone installed a winter tire with size different with factory
Discussion in 'Gen 5 Prius Main Forum' started by fzuray, Oct 28, 2023.
  1. fzuray
    fzuray New Member
    canada
    2023 Prius Prime
    has anyone installed a winter tire with rim size different with factory
    I got a prime phev 2023, and am looking for a rim and tire other than the factory size(e.g. 195 60 R17.)
  2. Blackat
    Blackat Active Member
    488
    356
    Colorado
    2023 Prius
    Limited AWD-e
    There are a couple threads about this.
    I bought 16" aftermarket wheels and winter tires from TireRack.
    They are the same height as OEM
  3. otatrant
    otatrant Active Member
    349
    212
    San Francisco
    2023 Prius Prime
    XSE Premium
    I installed 205/55R17 Michelin Cross Climate 2 on 17x7.5 inch MSW Type 48 rims from tirerack.com. Resulted in 0.4" loss of ground clearance. No issues other than an occasional rub when leaving drive way in a hurry. At the time I found it very hard to find aftermarket wheels that were factory size i.e. 17x6.5 inch.
    GcinFl likes this.
  4. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    215/60 R17 on 17x7 inch MSW Type 42
    otatrant likes this.
  5. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    205/60 or 215/55 are better matches for original circumference on 17". 205/60 exactly matches the standard 19", and 215/55 is in-between the standard 17" and 19".
    205/55 is smaller than standard sizes, 3% below the 19", which is at the edge of recommended changes, and legality in some countries.
    215/60 is bigger than standard sizes, 1.8% above the 19". Usually acceptable, but I'd be a bit wary for a winter tyre on this car.
    Toyota Finland had been telling dealers to offer 215/50R19 studded winter tyres for 19" cars (3% higher circumference), but I've read that they're now saying that's not acceptable, due to problems with snow build-up and potential well damage, and are specifying and type approving 17" winter sizes. 215/55R17 is the easiest to find, and what I already chose - Nokian Hakkapeliittta 10 on Toyota 17x6.5 rims (not the factory ones, but those offered as an option for 17" cars in Europe)
    #5 KMO, Oct 31, 2023
    Mendel Leisk and otatrant like this.
  6. purplePriii
    purplePriii Active Member
    275
    123
    Anyone has a picture with the 16" tires?
  7. Wind23
    Wind23 Junior Member
    purplePriii likes this.
  8. Jason Mosiman
    Jason Mosiman Junior Member
    Bend, OR
    2024 Prius Prime
    XSE
    Any issues with break calipers clearing if you went down to 17" wheels for winter from stock 19"?
  9. Mendel Leisk
    42,377
    The brakes are almost certainly the same, regardless of 17” vs 19” wheel. There have been clearance issues reported with 16” wheels though: clearance was so minimal that hidden weights needed to shifted. I wonder too: maybe a 16” wheel “clears”, but if a small piece of gravel gets kicked in there…
  10. Tooly
    Tooly Member
    51
    44
    Okanagan, BC
    2023 Prius Prime
    XSE
    215/50/18
    Calipers are the same no mater what size wheel came on your Prius. It not like the Prime is a performance variant warranting large brakes or better suspension.
  11. Bryden
    Bryden New Member
    Utah
    2023 Prius
    LE AWD-e
    I ran 10k miles this winter using 215/60R16 and Blizzak WS90... no clearance issue and they were GREAT in snow storms and snow < 6" deep...
  12. RMI_Chicago
    RMI_Chicago New Member
    Chicago
    2025 Prius Prime
    XSE Premium
    @KMO I recently got a 2025 Prius Prime and would like tires with some more sidewall without havi by to bug smaller wheels. I found an all-season tire in 215/50R19 size. It has 0.4 inches more sidewall than stock tires, which is nice. I don’t plan on driving in snow. Were the clearance issues with that size you mentioned in Finland solely because of snow build-up? Did the tires fit otherwise?
  13. Winston Smith
    Winston Smith Active Member
    476
    344
    OH
    2024 Prius
    LE AWD-e
    Just a caution - The front discs on AWD models are larger. Some data bases will show 16 inch wheels as fitting on FWD models but not AWD models.
    I suspect, but don't know, that this means some 16" wheels will fit over AWD front discs and calipers, but not all will.
  14. Hammersmith
    Hammersmith Senior Member
    2,499
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    You can cross check against PHEV listings. The AWD and PHEV use the same front rotors.
    FWD HEV - 11.1" rotor
    AWD HEV, PHEV - 12.0" rotor
    The calipers are also different, but figure the same roughly 1" difference in total.
    The AWD/PHEV rotors are also a little thicker. About 6mm or 1/4".
  15. KMO
    KMO Senior Member
    2,031
    751
    Finland
    2023 Prius Prime
    Those larger tyres would fit on the standard wheels fine.
    Can't say for certain, but I suspect the snow build-up is the main concern, and there's no hard issue with bigger sizes. Manual also has a "no snow chains on 19" tyres" bit, echoing the snow clearance thing. No other special "don't go bigger" warnings.
    With my 215/55R17 (smaller than normal 19"), I sometimes end up with caked snow rubbing against the tyres - anything bigger than the normal 19" would suffer that more.
    RMI_Chicago and otatrant like this.
  16. SXP
    SXP Junior Member
    38
    Huntington Beach, Ca
    2025 Prius
    I'm waiting for my 2025 XLE to be delivered later this month. I'm interested in improving the ride quality so was also thinking of buying an alternate set of 17" wheels. Would fitting a 225/60 R17 tire cause any interference issues due to the extra width? This tire size on 17" rims has an overall diameter of 22.3 " vs. the stock overall diameter of 22.8" (with the 19" wheels), so height shouldn't be an issue, but width?
    Feedback/advice appreciated
  17. SXP
    SXP Junior Member
    38
    2025 Prius
    Please ignore my post above.... screwed up the math royally!
  18. Winston Smith
    476
    344
    OH
    2024 Prius
    LE AWD-e
    nm.
    225/60 would be almost 9 inches wide.
    #18 Winston Smith, Jul 22, 2025
  19. Hammersmith
    2,499
    2,562
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I don't know what math you say you screwed up, but others on this site have been running 225 width without problems. The only issue would be that 225 is right on the edge for a wheel that's meant to take 195. My understanding is that +/-10mm isn't a problem, +/-20mm is starting to push things, and +/-30mm can maybe work but it's questionable. But if you choose to go with an aftermarket wheel that's a little wider than the stock wheel, then that's moot and 225 would be just fine.
    Stock wheels: 6.5"
    Best wheel width for 225: 7.5" (though 7.0" or 8.0" can work)
    SXP likes this.
  20. SXP
    SXP Junior Member
    38
    2025 Prius
    When posting the overall height of the wheel/tire package, I didn't multiply the height of the tire X 2 and then add that to the wheel diameter (17"). I added 17" + height of tire (once only).
    Anyway, I've decided on a 17" wheel (7" wide) and 215/60-17 tire which has the same overall height of the OEM 19" wheel/tire package.
    #20 SXP, Jul 23, 2025
