Has anyone installed the enginer PHEV?
Discussion in 'Prius PHEV Plug-In Modifications' started by alevinemi, May 28, 2009.
  1. toddwking
    toddwking Average Joe
    39
    San Francisco
    huh?? I thought something that balances your battery pack, monitors voltage of each cell, cuts off charging and discharging when when a cell reaches a certain limit (and sounds an alarm when it does so) is basically the [ame="http://en.wikipedia.org/wiki/Battery_Management_System"]definition of a BMS[/ame].
    Do edumacate me though if that's wrong, I'm a newb esp. as it relates to lifepo4 and would love to learn more about it & BMS's et al.
  2. Flying White Dutchman
    4,376
    313
    ok
    so every connector to a cell on this battery balancer is a small charger/discharger for 3.2 volts litium cells.
    mm wy dont we have these for Nimh battery's.. ( for a good price )
  3. drees
    drees Senior Member
    1,782
    247
    See as all it aims to do is maintain consistent battery voltages, it seems that it could be easily adapted to various NiMH cells if you can set the proper low/high voltage cutoffs.
  4. Flying White Dutchman
    4,376
    313
    prius Nimh batterys have a 7,2 vollts ( the 6, 1.2 volt cells are packed in 1 7.2 volt pack you can not take apart ! ) or 14,4 ( 2 in pair ) cell voltage.
    the Litium are 3,2 volt cell where you can not make 7,2volt or 14,4 volts from
    and what do these things cost?
  5. Muhahahahaz
    Muhahahahaz Member
    136
    CA
    ZOMG, this thread is very relevant to my interests! :D
    Let's get a group buy going! They say it's only $1,500 each if we order 100 of them... ;)
    (Or $1,200 each if we order 1,000 of them... though I'm not sure if that would be possible.)
  6. Flying White Dutchman
    4,376
    313
    even 100 wil be a problem i think.... but you never now ofcourse.
    10 group buy maybe and then 1500 for the 1995 ( 2 kwh ) kit or 2500 for the 2995 kit ( 4kwh )
  7. nveprius
    nveprius Junior Member
    In a group buy, I'd be in for 1...
  8. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    oops...misunderstood. thought you were talking regular SOC...actually Li can safely go to 20% (provides good safety margin) and up to near 100%.
  9. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    Hi!
    New member obviously...I've been lurking for a short time and joined specifically so I could post in this thread.
    IF the initial testing for this thing turns out positive, I'd be VERY interested in getting one. Especially since I'm only about 15 miles from Troy MI.
    Just bought a used 2004 Prius with ~48500 miles on it. Love it!!! Current tank is getting ~58 MPG on it.
  10. vertex
    vertex Active Member
    673
    144
    new york
    2018 Prius Prime
    I'm interested also in a group buy.
  11. MJFrog
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    OK, a little concerned about the above, esp. what I bolded.
    Are you referring to the BMS for the Prius or the add-on system?
    When you say the alarm didn't shut off until the system was charged, do you mean the OEM pack or the add-on pack? I would hate to get to work with that thing beeping and have it continue all day long until I got back home (no place to charge at work presently) to recharge. Or for that matter, going on a cross-country trip w/no place to recharge either.
  12. krousdb
    krousdb NX-74205
    581
    500
    47
    Raleigh, NC
    Ordered my 4kw kit with an extra converter. Should arrive in 15-20 days and I will install it myself shortly thereafter. I have a 136 mile r/t commute so this will provide highway assist mostly. If the results are satisfactory I will upgrade to 6 or 8kw. Updates to follow.
  13. Flying White Dutchman
    4,376
    313
    weill that fit in the box? 6 or 8kwh?
  14. krousdb
    krousdb NX-74205
    581
    500
    47
    Raleigh, NC
    4kw in the box, 2kw in place of the spare (possibly).
  15. Flying White Dutchman
    4,376
    313
    depends on how the voltage is setup
    if you have a 16 cell 2kwh pack = 16 cells in series ( i think is the input not 48 volts? dc-dc? ) and so that make's up for 52 volts ( 16 x 3,2v cells )
    so with a 32 it not in series but in parallel ( lets hope someone can confirms this )
    then you simple parallel a new pack.. but when its all in series.....then its a diferent story
  16. krousdb
    krousdb NX-74205
    581
    500
    47
    Raleigh, NC
    Multiple 16 cell 2kwh packs can be connected in parallel.
  17. kiettyyyy
    kiettyyyy Plug-In Supply Engineer
    205
    167
    West Covina, CA
    Finally! I've actually ordered the kit!
    So, It's arriving at my house on Saturday!!! I'll be removing my Plug-in Supply kit in the morning and possibly installing the new kit a few hours after that.. depending on when the thing arrives.
    Sad part was, Jack wasn't able to send me the second string of batteries because they come from overseas. I purchased the 4kwh kit. The extra 2kwh batteries will be coming in sometime in 15-24 days.
    Anyone want to buy a used(it's basically new :p) Plug-in supply kit?
    If this works out well... I will definately be putting in another 2 or 4kwh into the system.
  18. vertex
    673
    144
    new york
    2018 Prius Prime
    What is a Plug-in supply kit, and why are you swapping out?
  19. chenyj
    chenyj Member
    96
    115
    Troy, Michigan
    Guys,
    Don't need group buy. We are offering $500 discount for limited number of pilot testers who provide 30 day trip log for product improvement and marketing purpose in first come first serve basis. We need your help to push the PHEV movement forward. We hope the automakers can put this kit in the new hybrids so that it would be qualified for $2500 federal tax credit. Then it becomes free for all of you.
  20. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    I added a short summary of my impressions on this to Dan's
    thread on CleanMPG.
    _H*
