has anyone noticed their teeth deteriorating since getting a prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by arayan, Dec 4, 2012.
  1. yes
    2 vote(s)
    3.0%
  2. no
    58 vote(s)
    87.9%
  3. not sure
    4 vote(s)
    6.1%
  4. maybe yes
    2 vote(s)
    3.0%
  1. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    Our wisdom teeth are now curious...​
    Whirlwind likes this.
  2. arayan
    arayan Junior Member
    UK
    just thought i would get some answers in before i replied. well ppl have been complaining about a strange sulphur-electrical smell, that doesn't seem like the rotten egg smell you get from the catalytic convertor. I have experienced this with both my priuses so I thought perhaps it was sulphuric acid fumes or hydrogen sulphide (dont know my chemistry too well) coming from the 12V lead-acid battery in the trunk. the smell does seem to emanate from that area of the car, and i have had a friend agree. ppl in hyundai forums also complain about the same thing in their hybrids, and I would guess that their 12V lead-acid battery is also in the trunk.
    sulphuric acid gas is likely to be corrosive to teeth, ppl who work around lead-acid production lines have to be careful of this
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I've never had such a smell in either of my Prii. I would think that one's mucus membranes and respiratory system would also be negatively affected if the fumes were present in such a concentration that you could detect them or that they would affect your teeth.
    If this is something you are truly concerned with I would suggest removing your battery and inspecting it thoroughly for cracks in the casing or a weakening of the top cover material. I believe the battery is not really 100% sealed and that one can access the cells to replace fluids. If so then I could see how a seal could fail. Also check your venting hardware to ensure the battery is properly vented.
    arayan likes this.
  4. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Has anyone picked up on the fact that the OP is from England? <insert British stereotype joke here>
    Witness and PLSPUSH like this.
  5. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    Oh no you didn't...
    PLSPUSH and fotomoto like this.
  6. fuzzy1
    10,706
    Neither of my Prii had this odor.
    As F8L already stated, check the battery area to inspect for venting or fume problems.
  7. mrstop
    mrstop PWR Mode
    740
    329
    109
    Cincinnati, OH
    I haven't noticed any smell other than new car smell in mine either. If the smell is hydrogen sulfide, like F8L suggests, other symptoms are more likely to appear than teeth degradation.
    You could have the cars air quality tested. Also, make sure nothing died in your car. Another option would be to remove the 12V battery for some period of time and see if the smell goes away.
  8. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yes, four out of five dentist recommend the Prius to their patients.
    Much More Better and mylin like this.
  9. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    I believe that Prii come with AGM (Absorbed Glass Matt) batteries due to the installation in the passenger compartment. Here's a short description as to why they are used: "Since the battery system is designed to be recombinant and eliminate the emission of gases on overcharge, room ventilation requirements are reduced and no acid fume is emitted during normal operation."
    It's possible that someone changed your 12v battery with a regular lead acid battery. That would be bad because they do emit gasses that are harmful to you. You might want to check it ASAP and replace it ASAP with the proper battery if that is the case.
  10. bwilson4web
    16,535
    Not sure about the teeth but my hair fell out and I'm too fat.
  11. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Since I got my Prius my hair has fallen out and I've had a recurrence of cancer but at least I've lost weight.:D
  12. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Drive less and brush more. :)
  13. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Lemming of the BDA (British Dental Assoc) here, I am going to bet that odor you are sniffing is coming from the +12 volt battery that is located inside in the back of the car. At least in Gen II & III's. Check that the battery outgass tube is still connected to the battery vent, and is going through the floor for proper venting, and not clogged. If it is missing, all it is a 90° elbow for drip irrigation and 1/4" clear plastic tubing. $3 bucks worth of parts! But makes a big difference!
    richard schumacher and xs650 like this.
  14. Much More Better
    Much More Better Active Member
    655
    163
    It's true. I'm one of those 4. :)
    xs650 and spiderman like this.
  15. Former Member 68813
    3,524
    983
    US
    I see you are serious after all. If you do smell H2S odor indeed, it's coming from combustion of sulfur in fuel that generates gaseous SO2 oxidized to solid SO3 in catalytic converter and then released as H2S when reduced under rich conditions. You basically need to switch to higher quality low-sulfur gasoline. Lead acid batteries only emit H2 and O2 when overcharged and that is vented outside in Prius.
  16. KK6PD
    4,003
    946
    118
    Like I said, check the vent tube is still connected...... and properly routed to the vent hole!
  17. jnadke
    jnadke Junior Member
    71
    If you smell "rotten eggs", that is Hydrogen Sulfide. Over-charging lead-acid batteries can cause it.
    If you are smelling it, I would STOP driving the car immediately and have the 12V battery checked out. Your vent may be disconnected.
    Hydrogen Sulfide exists naturally in your body, but in large concentrations (as just about anything), it can be lethal. If you're smelling it, that is a good sign. That means the concentration is not lethal. The lethal concentration is well beyond what you can smell.
    (In case anyone was thinking it, yes, "rotten egg farts" are because your body is letting out hydrogen sulfide).
    It is most definitely NOT sulfuric acid. Sulfuric acid doesn't turn into a gas until 600 degrees Fahrenheit (300 Celsius). Your teeth are fine.
  18. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    I am driving a prius since 2007 !! NO dental issue ... :) can not wait to see what is this going ...
  19. bisco
    52,854
    i had 4 fillings in the spring, but the dentist said to lay off the hersey's kisses.:oops:
  20. fuzzy1
    10,706
    Your dentist is right. Never mind the fillings, there is plenty of much better chocolate available. :love:
    AlinaH_RD likes this.
