Has anyone removed the back seats?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by PriusBadass, Jun 29, 2019.
  1. PriusBadass
    PriusBadass New Member
    Wisconsin
    2018 Prius
    How difficult is it to remove the back seats of a 4th gen Prius? Has anyone tried it?
  2. Elektroingenieur
    2,515
    3,277
    Three Touring
    See my December 2017 posting for a general discussion of the procedure.
    alanclarkeau likes this.
  3. Ranko Kohime
    Ranko Kohime Member
    71
    32
    Ohio
    Two Eco
    I have, not terribly difficult, takes about 15 minutes.
    Remove the seat bottom by pulling up on the front, no tools necessary. The clips that hold the front pop rather violently, so brace yourself so you don't fall backwards and injure yourself. To reinstall, remove the clips from the front rail and clip them onto the seat U-brackets, then re-install the seat, it won't go if you try to insert the seat into the already-installed clips.
    With the bottom removed, you should see most if not all of the 14MM bolts you need to remove to get the seat backs out. The seat belt latches also use 14MM bolts if you're going for the full removal.
    Mambo Dave likes this.
  4. lech auto air conditionin
    830
    601
    261
    san francisco
    Be careful around the bright orange high voltage battery disconnect . If your finger or any tool accidentally hits it even lightly it’ll push down about a half inch to an inch and disconnect the battery and you will not even know it . When you go to start your vehicle it’ll say check HV battery and you’ll get a warning symbol on your dash and you will go nowhere .
  5. Rich32
    Rich32 Junior Member
    Thanks for the clue about removing the plastic clips and putting them on the seat brackets. I haven't seen anyone mention the electrical connector (sensor) under there. My car wouldn't run with the seat out until I disconnected it.
  6. Ranko Kohime
    Ranko Kohime Member
    71
    32
    Ohio
    Two Eco
    I am completely blanking on which connector that might be, as I recall disconnecting several. Do you happen to recall what it connects to? (What's confusing me is that the car wouldn't run WITH it connected, I would expect the other way around)
  7. Mendel Leisk
    40,583
    krmcg likes this.
