Has anyone tried priidash on a C
Discussion in 'PriiDash (TM)' started by Ramrodus, Feb 24, 2013.
  1. Ramrodus
    Ramrodus New Member
    Hi all,
    I just got a C and am very happy with it. Would like to know if anyone ahs tried priidash, or any other scan app successfully with the C. I would like to monitor the HV battery voltage without physically connecting leads to a multimeter.
    thanks
  2. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    510
    63
    I am guessing the C would be the same as gen 3. So you will need to modify the two text files formula.txt and command.txt to work with the C. Good luck and let us know how it works out for you.
  3. Ramrodus
    Ramrodus New Member
    Thanks, I will
  4. Ramrodus
    Ramrodus New Member
    How do i get the priidash files. the link to sourceforge does not work. Have been trying for a couple of days. even opened an account.
    Thanks
  5. 2009Prius
    2,705
    510
    63
  6. Ramrodus
    Ramrodus New Member
  7. Ramrodus
    Ramrodus New Member
    I got this error when running "./priidash" Im not really that computer literate. But i looked for the cygXft-2.dll and can't find it in cygwin. Should i reinstall cygwin?
    error while loading shared libraries: cygXft-2.dll: cannot open shared object file: No such file or directory
  8. 2009Prius
    2,705
    510
    63
    I am guessing that you are running from a Cygwin terminal, not a Cygwin X-terminal. Go to Start Menu - All Programs. You should see a "Cygwin Terminal" shortcut under "Cygwin" folder and an "XWin Server" shortcut under "Cygwin-X" folder. You want to click on the "XWin Server", not the "Cygwin Terminal". Then run PriiDash from the X-terminal. Good luck!
  9. Ramrodus
    Ramrodus New Member
    You are correct. However I don't see a "Cygwin-X" folder or an "XWin Server" shortcut.
    Thanks
  10. 2009Prius
    2,705
    510
    63
    You may want to go back to the Cygwin setup program to check if the components
      1. X11/xinit
      2. X11/libfltk-devel
      3. X11/libfltk1.1-gdi
      4. lib/boost
    are selected and installed.
