has anyone wired a trailer for their prius
Discussion in 'Gen 2 Prius Main Forum' started by priussoris, Apr 24, 2007.
  1. KTPhil
    KTPhil Active Member
    1,379
    And if you use a luggage tray, it's a good idea to use trailer lights on it.
  2. strasma
    strasma Junior Member
    Chicago
    2002 Prius
    For anyone else with a Prius OLDER than 2004, the instructions at
    Toyota Prius: How to Install Trailer Hitch Wiring - PriusDIY.com
    also work for the 2001-2003 models, with two slight changes:
    1) No need to remove the (non-existent on older models) driver's side 10mm tie down bolt and hook
    2) A 4 foot splice of stranded #12 yellow wire needs to be added to the negative battery lead, as the battery on the older models is on the driver's side of the trunk.
    As for weight limits, I have the trailer hitch formerly sold by Coastal Tech on my 2002 Prius. It was recommended for a tongue weight not to exceed 200#, and a trailer weight not to exceed 1000#. I've used it successfully with a hitchriders.com dual trike rack that weighs at least 50#, plus another 50# each for 2 trikes, and will soon be using it with a 200# Harbor Freight trailer designed to pull a 600# boat, adapted to instead pull a 100# tandem trike.
