Has my oil been overfilled by Toyota?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bgustafson, Apr 20, 2018.
  1. William Redoubt
    William Redoubt Senior Member
    1,215
    1,165
    Coronado Island, California
    You save time. You can do it in 20 minutes. You spend more time at the dealer than that.
    Bgustafson likes this.
  2. Bgustafson
    Bgustafson Active Member
    259
    222
    Chicago
    Yeah it took them 1hr 15min..
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,146
    Tampa, FL
    Interesting. My PiP is a 2013 and has a flat dipstick.
    paprius4030 and Mendel Leisk like this.
  4. Mendel Leisk
    41,023
    The sun doesn't rise and set on Mobil.
    It usually takes me at least an hour to DIY, but I'm doing stuff like taking the full engine underpanel off, start the drain and let it drip, check the CV boots. No point in rushing.
    jerrymildred likes this.
  5. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I wonder if he has the right dipstick?
  6. Simonak
    Simonak Member
    Maybe they saw you are over 100k and fill more so when you burn oil you don't run too low.
  7. Bgustafson
    259
    222
    Chicago
    That's entirely possible. I'm the second owner.
  8. Prodigyplace
    12,466
    11,717
    Central Virginia
  9. Elektroingenieur
    2,515
    3,281
    Three Touring
    The listing on parts.toyota.com gives a second part number for the oil level gauge sub-assembly, 15301-37030, which applied only to 2012–2014 models and has been superseded by 15301-37010, the current part number for all Prius models from 2010 through 2018.
    Google Image Search found a picture someone posted of a new gauge in a bag labeled 15301-37030. It does have some extra bends near the end, so the change in part numbers would seem to account for the difference from the 15301-37010 (example for sale on eBay).
    I have no idea why Toyota changed the design, though.
    Prodigyplace and Mendel Leisk like this.
  10. paprius4030
    2,077
    296
    York,Pa.
    When you click on the link above it's in a foreign language but it says Corolla?????
  11. Elektroingenieur
    2,515
    3,281
    Three Touring
    Да, разумеется. There are Toyota cars in Russia, and the same part was used on the Prius and the Corolla for several years. If you scroll through the photos, you’ll see one of a bag with a Toyota label for part number 15301-37030, containing a dipstick with bends like those also seen in the photos of post #15.
  12. jerrymildred
    11,517
    14,146
    Tampa, FL
    Wrong dipstick seems pretty unlikely, but it sure would explain the oil being so high on the dipstick.
    Mine is 20-1/4" exactly from the full mark to the base of the handle where it hits the top of the tube. How does yours compare, @Bgustafson?
    #32 jerrymildred, Apr 22, 2018
    Mendel Leisk and Prodigyplace like this.
  13. paprius4030
    2,077
    296
    York,Pa.
    I thought is was Russia Comrade ;)
  14. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    515
    Outside Philly, PA
    My daughter's Corolla has a dipstick like that - it bends at the bottom of the tube to enter the sump. +1 wondering if this is the right length for your car (it is a different engine, obviously).
    Once when a dealer did an oil change on my old Subaru Forester they returned the car with a shorter dipstick in it- don't know if it was from a WRX or Impreza. I took it back (they initially thought I was crazy until the manager found mine on the tech's bench). I think they were using that to do a controlled overfill of a quart high since they were (and still are) having serious oil burning issues on some engines. The only reason I knew was because mine had a T handle and the one they forgot to keep had a ring for a finger pull. (y)
  15. arkadiy
    arkadiy New Member
    Vancouver, BC, Canada
    2001 Prius
    I
    Yep, that's the only way. I newer let anyone touch a single bolt on my vehicles.
    May be later, after i hit 80 y.old. :)
  16. arkadiy
    arkadiy New Member
    2001 Prius
    I
    To read oil level correctly, i use to do another trick. Try apply slight twist moment while inserting and pulling stick into tube. And do it quick enough, to prevent oil spread.
    Good luck to everybody.
  17. tvpierce
    tvpierce Senior Member
    951
    882
    Maine
    2013 Prius v wagon
    It's the correct dipstick. I have the same one in my '13 V wagon. I assume the bends are to put some distance between the dipstick and the tube when being extracted -- but that's just a guess.
    It is interesting that among 3 2013 cars (@Bgustafson, @jerrymildred and mine) two have the "kinky" dipstick and one has a flat.
  18. jerrymildred
    11,517
    14,146
    Tampa, FL
    My wife's 2007 has a little 90° twist at the bottom end. I assume that's also to keep the flat surfaces farther from the tube walls, but I'm not so sure that it does much good.
  19. Mendel Leisk
    41,023
    @jerrymildred posted the measurement of his, the flat style, in post #32. If @Bgustafson measures his for comparison, this question will be cleared up. I'm guessing they're the same.
    Prodigyplace likes this.
  20. Erik Owens
    Erik Owens Member
    162
    59
    This is one of the more useless threads I have been privileged to read. (n)
    Elektroingenieur and Grit like this.
