Has running out of gas killed my hybrid battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wideslider, May 6, 2014.
  1. wideslider
    wideslider New Member
    Sydney, Australia
    FIXED!!!!!!!!!!!!!
    I went back to the car with a can of Aerostart. As one of the members had informed me that the ICE was not in fact running but just cranking from the hybrid power pack I came up with a theory of how I could charge the battery. I had my girlfriend start the car with her foot flat on the gas pedal. I sprayed Aerostart directly down the throttle body which let the ICE run and continued this for about 15 minutes. (The ECU must cut the fuel pump or injector pulse once the Hybrid battery has been completely drained). Once the battery had two bars in the display the car ran by itself without assistance from the Aerostart. I have now put around 50miles on it and everything appears to behave as normal. My economy meter still reads the same as before so hopefully the battery hasn't suffered to much.
    There are no longer error codes in the ecu.
    I hope this helps someone in a similar circumstance as it stressed me out!!!
    northwichita, fuzzy1 and wjtracy like this.
  2. wideslider
    Sydney, Australia
    P.S I'm actually living in Sydney, Australia but spend half my life in LA hence owning a Prius here. The Prius in Australia is the most expensive passenger car in the Toyota range at $56,000 in i-Tech trim!
  3. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Glad you got it going wideslider. :)
    BTW, are you currently in Sydney or LA?
  4. wideslider
    Sydney, Australia
    Currently in Sydney. Cheers
  5. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Ok, then in that case you're super lucky that you didn't need to take it to the dealer for repair. (y)
  6. WNY-HYBRID
    WNY-HYBRID Member
    244
    48
    NY
    I'd be interested in one of those chargers Eric, what are they going for ?
  7. wjtracy
    wjtracy Senior Member
    11,366
    3,608
    Northern VA (NoVA)
    ....ingenious! But put your locale in your profile and don't run out of gas next time!
  8. Mendel Leisk
    41,328
    If that's the case, and you've managed to revive the car with no lasting ill effects, there's something wrong with Toyota's engineering.
    Anyway, congrats, and yeah: don't ever tempt fate again, fill up whenever it's getting low. ;)
  9. ericbecky
    ericbecky Hybrid Battery Hero
    4,425
    3,299
    Madison, Wisconsin
    Still making last minute adjustments. Aiming for $399 plus shipping for basic unit without discharger capability. Slightly more for one with discharger compatibility. Discharger is separate cost.
    vskid3 likes this.
  10. gary sciascia
    gary sciascia New Member
    When I first got my gen III I ran it out of gas on purpose to see how many miles I could go when the low fuel segment started blinking. Car used 10.6 of 10.7 capacity. A very impressive working volume of gas. Anyway, I had a 2 gallon can of gas with me. After running out of gas, I filled the 2 gallons in, went to the gas station 2 miles down the road and filled up. I haven't had any problems since. Been 10,000 miles so far. Getting 45 mpg. I drive with a heavy foot. Like to use the power mode when needed. If your battery is near the top (fairly well charged)and you run out of gas why wouldn't the battery stay at the same state of charge ? You run out of gas the car stops. Traction battery usage is terminated. I guess you could draw down the regular 12 volt batter if you were silly enough to keep the headlight and all other electrical loads on. But that doesn't mean you would kill the 12 volt battery either. Might need to be charged. But that's it.
  11. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Hi Gary. There definitely should be no problems if you stop straight away after you run out. Where the problems sometimes arise is when people run out of fuel (or otherwise lose engine power) and just keep trying to limp along on electric power until the HV battery is nearly completely drained. With some of the older gen2's, where the HV battery can already be a bit old and tired, some people manage to finish them off completely doing this.
  12. Patrick Wong
    18,200
    6,500
    "When I first got my gen III I ran it out of gas on purpose to see how many miles I could go when the low fuel segment started blinking. Car used 10.6 of 10.7 capacity."
    The 3G Prius has an 11.9 gallon fuel tank according to the Toyota website:
    Toyota Prius Interior, Exterior & Safety Features
    Since that model's fuel tank does not contain a flexible bladder, it is possible to realize more of the specified capacity in regular use.
    The 3G hybrid vehicle ECU apparently offers more aggressive protection of the traction battery compared to the 2G HV ECU which will allow the car to be driven for some distance when the gasoline engine is inoperative.
