hatch door sensor
Discussion in 'Gen 3 Prius Technical Discussion' started by 707steve, Jul 15, 2019.
  1. 707steve
    707steve New Member
    Santa Rosa Ca
    I have a 2014 with less than 80000 miles. Several days ago I was unable to close the hatch without the door open light coming on and consequently driving with the obnoxious beep that comes with an open door. I took it to the dealer today and they will fix it for $550. They say the door hatch assembly is broken and needs to be replaced. I've owned other Prius' and driven them to 150000 miles without something like this happening.
    Has anyone had a similar experience and is the $550 fix the only way?
    52,820
    welcome!
    call around to some local mechs to see how much they want
  3. ASRDogman
    ASRDogman Senior Member
    8,056
    4,084
    You could buy the latch and replace it yourself. It's not that hard.
    There are youtube videos. :)
  4. JC91006
    16,936
    8,647
    Are you sure it's not the rubber seal on the hatch that's preventing you from shutting it?
  5. Mendel Leisk
    42,323
    I've got a fuzzy memory: someone here disassembled and repaired theirs successfully. Pretty sure they started a thread on the subject. Wasn't able to find it with google search though.
