Hatch Shocks Stiff, Easy Fix?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by geeter, Jan 20, 2013.
  1. geeter
    geeter Member
    208
    16
    Chicago
    So the hatch struts that slowly open and close and lock the hatch up are very stiff. They get stuck on the way up and I have been hitting my head on the hatch door. My wife did it the other day while carrying our kids and hence my need to fix.
    Does anyone have any suggestions on how to lube these? Do they just need replacing after sometime, and if so, are they an easy fix? Thanks.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    They are gas struts and probably slow with the cold weather. You can get replacements at either the dealer, auto parts store or online. They are very easy to change.
  3. geeter
    geeter Member
    208
    16
    Chicago
    Thanks. I revised my search after this post and found quite a few postings. I appreciate the response. Do you have any idea how much I should pay for a set?
  4. frodoz737
    frodoz737 Top Wrench
    4,805
    2,561
    33
    jd is correct, however occasionally wiping down the extended inner rod with LPS or WD40 does wonders to maintain proper operation and extend the life of these struts.
  5. geeter
    geeter Member
    208
    16
    Chicago
    I will try that first. I just called the local dealer, the parts guy told me the struts are $135.01. I am pretty sure the strut should be 20-30 each.....does that sound right?
  6. frodoz737
    4,805
    2,561
    33
    Unless you insist on using the Toyota part, Autozone or most auto parts store will cost what you were expecting. They call them support lift.
  7. geeter
    geeter Member
    208
    16
    Chicago
    Thanks. I used a bit of PB Blaster on the post and it didn't do much (except make the car stink). I will stop over to the parts store today.
  8. gliderman
    gliderman Active Member
    751
    225
    You may be changing struts that are perfectly good. Mine slow down when it gets cold, and I have also hit my head a couple of times. Just need to pay attention. It is 75 degrees today and I just got back from shopping and they are normal. When it was cold, they were slow.
  9. geeter
    geeter Member
    208
    16
    Chicago
    75 degrees! That sounds amazing.
  10. Mendel Leisk
    42,347
    Ours are doing that too: get the hatch about half-way up, then almost stall. A little nudge will get them the rest of the way. It's sorta cold here, just around or slightly over freezing.
  11. jayrider
    jayrider Member
    163
    17
    southwest illinois
    Have an appointment to have them changed under warranty. My wife cracked her head on the lift back. They won't stay up. I'll give you a report on the new ones. 25 degrees here but they have been acting up during the summer as well.
  12. jayrider
    jayrider Member
    163
    17
    southwest illinois
    The lifts are covered under warranty but they have to order a set. If I need them out of warranty will go to the auto parts store -- they have a lifetime warranty and are easy to replace.
  13. geeter
    geeter Member
    208
    16
    Chicago
    Would they be only under the bumper to bumper? I am at 52K and I am getting close to the 60K expiration of the powertrain warranty.
  14. jayrider
    jayrider Member
    163
    17
    southwest illinois
    They won't be covered under the power train warranty. Go to autozone and get lifetime lifts.
  15. geeter
    geeter Member
    208
    16
    Chicago
    Thanks sir. I will go check them out.
