Hatch strut/lift supports recommendation?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Tomek310, Feb 9, 2017.
  1. Tomek310
    Tomek310 Junior Member
    89
    Riverside
    Hi guys. Has anyone replaced worn hatch supports? If so, what are your recommendations? I've seen some brands on Amazon but am not sure which ones to go with. I want a smooth lift and damper at the end to prevent over extension.
  2. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
    I installed 'Strongarm' rear hatch shocks last summer after my old ones were failing. Not always staying up. 'don't you just hate that...'
    You can find them for less than $20 on the 'A' word site.
    Old ones wouldn't hold the rear hatch up...let alone lift it like these do.
    I don't think these are specific to the Gen2 Prius - I had to rotate the head of the shock 180 degrees as it was facing the wrong way - other than that - straight bolt on.
    StrongArm 4686 lift-supports
    Just remember - I had to rotate the head of the shock 180 degrees as it was facing the wrong way - other than that - Straight bolt on. Super StrongArm. :) Super cheap compared to OEM.... and stronger then oem replacments. PartsGeek had some other options - but i'm def happy with my purchase.
  3. Justdidit
    Justdidit LVNPZEV
    1,880
    711
    75
    Carrollton, Texas
    Four Touring
  4. Tomek310
    89
    Riverside
