Hatch tie down
Discussion in 'Prime Accessories and Modifications' started by Tickwood, Sep 27, 2021.
  1. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    has anyone mounted any type of eye (or whatever) in the hatch to enable tying it down with ripe or bungee cord over oversize cargo. I don't know what happens when you drill into carbon fiber.
    Thanks
  2. ChapmanF
    19,033
    Hasn't the latch mechanism got a sturdy metal loop?
  3. Tickwood
    334
    101
    San Diego
    2020 Prius Prime
    On the floor, NOT on the hatch
  4. ChapmanF
    19,033
    Hmm, they swapped it then. My Gen 3 has the metal loop in the hatch, and the latch mechanism in the sill.
    Either way ....
    I would typically think of just closing a carabiner into the latch mechanism (whether that's in the sill or the hatch), and then tie something from that to the metal loop (whether that's in the hatch or the sill).
  5. pghyndman
    pghyndman Active Member
    498
    466
    CT shoreline
    Open the hatch and use a piece of rope (or screwdriver, or?) to push the moveable latch over the rope or (?) you want to use as a tie down (putting it in the locked position). When you want to open and release the rope, pull up on the hatch open handle as you normally would to unlock it (of course the key needs to be nearby). Lock.jpg
  6. Tickwood
    334
    101
    San Diego
    2020 Prius Prime
    Many thanks, That should doe it.
  7. EdPalmer42
    EdPalmer42 Member
    135
    75
    2020 Prius Prime
    Something like a large carabiner, ubolt, or screw-closed chain link should also work as a convenient way to hook onto the top.
  8. Old Bear
    Old Bear Senior Member
    712
    1,050
    Boston, Massachusetts USA
    Yes. And this has the added advantage of making the car think that the hatch is closed and latched -- which stops the continuous beeping that normally warns that the hatch is open when the car is in Drive.
  9. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,604
    Taylors, SC
    Use one of these.
    Keeper (85110) 3' x 1" Trunk Tie-Down
    pghyndman likes this.
  10. Tickwood
    334
    101
    San Diego
    2020 Prius Prime
    Thanks, I ordered one. (it is on eBay)
