Hatch will not open when cold
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by elfprofessor70, Jan 8, 2015.
  1. elfprofessor70
    elfprofessor70 Junior Member
    Sylva, NC
    My problem is the hatch lock will not release if temp is 40 degrees or below. Above that figure it works perfectly. What gives??
    52,888
    makes no sense. you probably have to dismantle it and examine all the parts.
  3. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    Could be something wrong, but note that the lift struts that help lift the gate can be less effective in cold weather. This makes the hatch feel quite a bit heavier, and may give the impression that its stuck but may just need a bit more heft.
  4. GregP507
    GregP507 Senior Member
    3,002
    481
    I use WD-40 on all the rubber seals. Keeps the ice from bonding to the rubber quite so much.
    #4 GregP507, Jan 8, 2015
