Hatchback door won't stay up
Discussion in 'Gen 3 Prius Main Forum' started by My2010prius, Mar 13, 2020.
  1. My2010prius
    My2010prius New Member
    Los Angeles
    This morning I lifted my 2010 prius hatchback door and it slowly kept coming down. It will not stay up when opened. The last time I used the door was 12 days ago without any issue. Has this ever happened to anyone?
    Other info that may or may not be useful: I got an oil change 3 weeks ago and about a month ago I had to repair the gas cap as it was stuck. A year ago the body (door, gas cap area, and trunk) of the back driverside was replaced due to an accident.
  2. Grit
    Grit Senior Member
    6,577
    4,229
    Wilkes Land
    No.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Welcome to Prius Chat(y).
    Sounds like the hatch struts have failed or lost the gas in them;).
    Not a hard thing to swap out:).
    Good luck and keep us posted(y).
    Bay Stater likes this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
  5. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    Blue pill?
    vlxerdon and Mendel Leisk like this.
  6. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    Raytheeagle likes this.
  7. Ronald Doles
    Ronald Doles Active Member
    230
    280
    Columbus, OH
    2015 Prius v wagon
    I ordered some from ebay for our 08 Odyssey. The ones I received looked exactly like the original ones that I removed but the pressure in the shocks must be higher because the tailgate is harder to push closed now. No problem holding the tailgate open just more force than the originals required to close it.
    Just because a vendor says that a part is a direct replacement doesn't mean that it will work exactly the same as the original.
  8. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    Eight years ago, we bought an 05 Explorer. About a year later, I replaced the hood lifts in “an abundance of caution” after the hood fell once, just fast enough that it touched my head. The replacements failed completely in 18 months. Now I have an 18 inch long piece of 1/2 PVC pipe that I use as a prop rod. I remind myself of that every time I thing about adding the lift supports that are available aftermarket for the Prius hood. LoL
