Haunted radio???
Discussion in 'Gen 2 Prius Technical Discussion' started by Tammy7287, Mar 25, 2010.
  1. Tammy7287
    Tammy7287 Junior Member
    83
    Maple Valley, WA
    Twice in the last 3 weeks or so I have encountered a problem with the radio in my 2008 Prius.
    The first time it happened I was at a stop light. Today it happened as I was driving down the freeway. For some reason the radio decides it is not loud enough and it will adjust the volume on it's own. Sometimes it's only 1 or 2 levels but it also bumps it up or down by 10 levels.
    Has this happened to anyone else? Any suggestions on what to do? I know the dealership will want to recreate the problem but I can't MAKE it happen....it just does.
    Any help would be greatly appreciated.
  2. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    Yeh, we noticed the same thing the other day on a trip. I concluded that the volume control on the front of the radio was in a "funny" position (in these digital controls, the volume knob only runs an encoder and I suspect that the control was left with the encoder half way between segments allowing the slightest vibration to cause the encoder to generate an up or down signal). When I "tweaked" the volume knob slightly the problem went away.
  3. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,803
    1,170
    Auburdale FL
    I think there is an auto volume setting in the menu. Also, what does pushing in the volume knob do?
  4. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    Pushing-in the volume knob makes it become flush with the rest of the console. It has no effect on its operation at all.
