Have a 2011 Prius with 5000 miles.
Discussion in 'Newbie Forum' started by sjohn1, Jun 22, 2012.
  1. sjohn1
    sjohn1 Junior Member
    Twice in the last week the car has lost power without warning. First time it took several tries to get the accelerator to respond. The dealership can find nothing wrong. Has this happened to others? Any ideas as to cause.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Welcome aboard! Sorry to hear the problems. Could you further explain "accelerator to respond"?
    There have been people that have accidentally hit the Park button and or hit Neutral by striking the stick shifter (for a second or two). In both cases, the car goes into Neutral and will coast.
    When it "lost power", was it still in Ready mode?
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Were you driving on a slick surface?
  4. sjohn1
  5. sjohn1
    The car suddenly begin to slow down. The accelerator did not respond to pressure as if it were in neutral. It was in the Ready mode. The first time, I suppose there is a slight possibility that I might have accidentally hit the stick shift. The second time, I know I did not.
  6. sjohn1
    It was a dry surface
  7. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    The accelerator will not respond if in neutral. At most you will get it to rev to about 1100 rpms and that is it. The only reason it does that is for service personnel running tests.
    So the second time,,, you were positive it was still in Drive and it was in Ready mode?
  8. sjohn1
  9. sjohn1
    I am sure the second time the car was in drive and was in ready mode. I know I did not touch the gear shit. However, I am sure that is what the dealer thinks I did.
  10. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Good thing you didn't touch that. :)
    Node yellow triangle/codes? If not, this will be a really hard one to track down.
  11. sjohn1
    Thanks for your input. We are in a wait and see mode.
  12. Jason dinAlt
    Jason dinAlt Member
    183
    61
    Overheating causing shutdown?
    Anything blocking traction battery vent?
  13. bisco
    52,762
    what do you mean by 'the first time, it took several tries to get the accellerator to respond'. you mean you pumped it a few times and then the car started to accellerate again? and what exactly happened the second time?
  14. sjohn1
    W
    I turned the engine off then restarted it. When I put it in gear the parking light did not go off and the accelerator did not respond. After several tries, the parking light went off and the accelerator responded. Sorry to take so long to get back to you. Thanks for responding to my post.
  15. sjohn1
    Well, Ive had it into Toyota service twice and nothing was said about the possibility of overheating or the battery vent.
  16. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    "When I put it in gear the parking light did not go off and the accelerator did not respond. After several tries, the parking light went off and the accelerator responded."
    This sounds like a switch/contact problem. It also appears to be random so unless it happens when you are on a test drive it's going to be tough to get the dealer to believe you.
    I'd try pressing for a shifter replacement, starting with, "What happens if the shifter doesn't make or maintain a good contact?"
  17. JimN
    7,028
    1,117
    South Jersey
    The next time it happens, if you can, don't futz with it. Call SC & have them send someone out to either look at it or pick the car up.
  18. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    What do you mean by "parking light"?
    Was your foot on the brake when trying to accelerate? Do you drive with both feet?
    BTW, it'd help to title your post better...
  19. richard schumacher
    7,683
    1,065
    United States
    "SC"?
    Shifter sounds like the most likely problem.
