have no voice guidance on NAV
Discussion in 'Gen 2 Prius Audio and Electronics' started by osofast10, Aug 24, 2011.
  1. osofast10
    osofast10 New Member
    61
    Va
    I have no voice guidance on my nav. I am able to see where i'm going and if i'm looking at the map i can see when i have to turn but i have no voice guidance and it's driving me nuts:rant: any idea how to turn on this function?
  2. seether166
    seether166 New Member
    32
    Syracuse, NY (USA)
    Isn't one of the voice commands "Louder"?
    The car then responds to you, "Guidance will be at this level."
    I'm sure there is a menu option for this too...I'm just pulling this part out of memory. Of course, I see you have a 2005 and I'm familiar with the 2011. Sorry if this doesn't help.
  3. osofast10
    61
    Va
    i've tried that, but nothing, it's like if the voice guidance is mute
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    You can disable "turn by turn" guidance. Look in the Nav menu for all of the options.
    Tom
  5. osofast10
    61
    Va
    how can you enable turn by turn? mine is turned off and i've tried everything to turn it on.
  6. qbee42
    18,058
    3,074
    Northern Michigan
    It's in the Nav menu, which is invoked by one of the Nav buttons on the side of the screen.
    Tom
  7. Tideland Prius
    16,159
    Do the following
    MENU --> SETUP --> go to page 2. (or SETUP --> Navigation --> Detailed Navigation Settings --> go to page 2)
    Find "Auto Voice Guidance" and turn that on. Also ensure that "Voice Guidance in All Modes" is on as well
  8. osofast10
    61
    Va
    i did that and still no luck.... UGH...
  9. qbee42
    18,058
    3,074
    Northern Michigan
    Do you have the guidance volume turned up?
    Tom
  10. osofast10
    61
    Va
    LOL, yes, all the way up.
  11. Tideland Prius
    16,159
    If you press the MAP/VOICE button, do you hear the instructions? (remember, you have to be under guidance).
  12. osofast10
    61
    Va
    nope, hear nothing....
  13. Tideland Prius
    16,159
    Then it might be a speaker issue. Have the driver's side tweeter inspected (I believe that's the one that's used).
  14. Sarge
    Sarge Senior Member
    1,302
    758
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    I would agree with Tideland - sounds like it may be a speaker issue.
    If you use Bluetooth with your phone, does that work? Both use the same front driver side speaker.
    Alternately, try adjusting your fade/balance on the radio all the way to the front driver side and see if you get any audio.
  15. osofast10
    61
    Va
    blue tooth works perfectly.... i just don't get it.... hhmmm maybe i just need to buy a new navi disk? or a new system all together?
  16. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    im having this same issue in my 2010 prius factory nav ?
