Have Some Morimoto Elite HID Harness Installation Questions ?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Markee, May 26, 2016.
  1. Markee
    Markee Member
    336
    South Florida Broward County
    Trying to do the install of the Morimoto HID kit with harness on my 2013 and had a few question ?
    1. Do I need to do anything with is wire in the below picture or is it just optional for a different install and i can get rid of it ?
    2. I'm not sure exactly where to hook up the + and - power connectors off the harness ?
  2. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    I've posted this picture in several threads:
    Where the red wires attached to the open 1/4 inch push on terminals are where you would connect your harness (to one of these terminals) for your +12v power. Think of it as your positive terminal on your battery.
    The negative wire can be attached under any good body ground point (bolt).
    I don't have any experience with Morimoto HID harnesses, so I can't say for sure whether you need that other wire for your installation. They may just be generic adapters to connect your oem lowbeam connector to the ballasts, which you won't be doing, since you are using a relay harness.
    If your relay harness has a connector that plugs right into the driver's side lowbeam connector (the one that originally plugged into the lowbeam bulb), then you don't need those wires in the picture.
    #2 xliderider, May 27, 2016
    Dylan Doxey likes this.
  3. xliderider
    8,140
    3,280
    Honolulu, HI
    FYI , Toyotas usually have the connectors wired such that you might have to flip the connector that attaches the HID to the oem lowbeam connector 180 degrees to make them work.
  4. Markee
    Markee Member
    336
    Thanks for the quick reply
    So your saying I'm good to go connecting up the ether one of the 2 empty terminals bottom arrow in my picture and looks like i can feed the wire in from bottom of the fuse box through where the white wire flows top arrow ?
  5. xliderider
    8,140
    3,280
    Honolulu, HI
    Yes, that's exactly how I feed my wires into my fuse box.
  6. Markee
    Markee Member
    336
    Getting ready to finish up the install
    Was wondering if theirs any trick to popping out those clips that hold down the side panels the ones that you hide the Ballasts behind ?
  7. xliderider
    8,140
    3,280
    Honolulu, HI
    Did you test everything out yet? It would suck to get everything all buttoned up, then find out you have a problem. :(
  8. Markee
    Markee Member
    336
    My problem right now is how to pop out the clips without just ripping the chips up or out ?
    Anyone ??
  9. xliderider
    8,140
    3,280
    Honolulu, HI
    It's not the standard type, where you use a small screwdriver to pop up the center to release the clip?
  10. Markee
    Markee Member
    336
    Yeah trying that but its not releasing the clips don't want to just tear them up
  11. Markee
    Markee Member
    336
    What a pain i could not get those bulbs to go in playing with it for hours tore up my hands
    I've done the H11 to H9 conversion those bulbs go right in no problems stock bulbs no problems
    I don't know if they sent me the wrong bulbs or what pissed to the max Sucks the place not even opens on weekends
  12. StarCaller
    StarCaller Senior Member
    1,284
    733
    Cedar Crest, NM, USA
    are you working on weekends?
    didn't you check the bulbs before you were trying to put them in?
    doesn't your community college offer courses in common sense?
    :sleep:
  13. xliderider
    8,140
    3,280
    Honolulu, HI
    Wow, pretty harsh SC. :(
    Markee, are you trying to put it in with the ground wire at around the 4 o'clock position, then rotate down to 6 o'clock position to lock in place?
    Maybe, they sent the wrong type of H11 bulbs? Is the ground wire between the mounting tabs (H11b), and not centered on a mounting tab (H11a)?
  14. Markee
    Markee Member
    336
    yeah did the 4 o'clock position, down to 6 o'clock position those bulbs would not go in
  15. xliderider
    8,140
    3,280
    Honolulu, HI
    Sometimes, the rubber seal/gasket is a little thick, you might need to push in/forward before trying to turn the bulbs.
    You can also try swapping the gaskets from your H11/H9 halogen bulbs to the HIDs, if they're thinner.
  16. Markee
    Markee Member
    336
    Yeah i read that about the gasket tried pushing way hard messing with it for hrs its not going on no way no how tried many many times something just ain't right shouldn't be that difficult the stock bulbs and converted bulbs go right one no problem
    I'm burned out
  17. xliderider
    8,140
    3,280
    Honolulu, HI
    Well, try swapping the seals with the halogen bulbs.
  18. Markee
    Markee Member
    336
    yeah maybe try that tomorrow swap the gaskets shouldn't have to do that for what this shit cost
  19. StarCaller
    1,284
    733
    or put a tiny tiny amount of silicon grease on the gasket/
    helped me a lot/
  20. Markee
    Markee Member
    336
    Swapped out the gaskets and they went on easily all done
    Thanks for help
