Have to Laugh at this one
Discussion in 'Gen 2 Prius Main Forum' started by drone13, Feb 15, 2022.
  1. drone13
    drone13 Active Member
    140
    115
    SoCal
    I purchased a used 2007 Prius with 130K on it a little over a year ago. Been doing great except for a middle aged battery I replaced with NPB 6 months ago. No codes and still worked OK, just on the tired side and rated at 60% by Dr Prius at purchase. This was factored into the purchase price, so a planned upgrade.
    A couple of weeks ago it flagged the P0420 code. Yikes... I'm 3 months away from having to smog cert in Cali, so not good. I did some data logging and the rear O2 just didn't look right. It would sometimes, randomly, straight-line at around .7v when the motor was off. And sometimes show 0v when the engine was on for around 30 sec. This didn't happen real often and I happened to catch it on one of 4 logs I recorded. So for sure the rear sensor was worth pulling and testing.
    When I pulled the O2 there was a strange bulbous wad of tape near the connector in the car interior, which was apparently a repair with about half a roll of electrical tape. It took me 20 minutes of heating and unwrapping the tape to see was under there. I took my time because I did want to see what lurked under the tape. What I found was comical, as shown in the pic.
    Pretty janky huh? The good news is a new Denso O2 and the car is fine again. Thought you all would get a kick out of this, and I guess I dodged an expensive bullet.
    Raytheeagle and xliderider like this.
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    OMG, no solder, wires twisted together... it's amazing that it even worked for a while.
    Edit: Zoomed in on the picture, there appears to be solder on the wires, but are they just individually tinned, and not actually soldered together?
    #2 xliderider, Feb 16, 2022
  3. drone13
    140
    115
    SoCal
    I think the picture doesn't do it justice. There are big globs of solder and lots of areas with no solder. I'm surprised it lasted a year without throwing a code. Each wire had a huge amount of tape and the whole thing was then wrapped with a ridiculous amount of tape. It looked like the bulb used to pump up a blood pressure cuff. I thought maybe the result of a repair after a stolen cat, but I verified the cat was OEM during pre-inspection on a lift which I verified myself, so unless they found another used cat (illegal here) I'm not sure what to think other than maybe the original O2 got snagged on something and ripped the wires. That still makes no sense since the rear O2 is not very expensive. Just the labor of that much tape wrapping would exceed the cost of a new O2. People do weird things sometimes.
    jerrymildred and xliderider like this.
  4. PriusCamper
    PriusCamper Senior Member
    13,351
    5,396
    Pacific Northwest, USA
    Yet more proof that DIY car repair is definitely not for everyone... :) Congrats on finding such a cheap&easy fix! With so many who wrongly think the P0420 code will go away by messing with the O2 sensor it's nice to finally see someone legit fix it that way.
  5. ColoradoBoo
    ColoradoBoo Senior Member
    1,326
    946
    Monument, Colorado USA
    Wow, that IS funny....glad you got it fixed!
    There are are few mechanics on YouTube who post short videos from customer cars and some things are hilarious...
    jerrymildred likes this.
  6. ChapmanF
    18,897
    I'll say.
    ColoradoBoo likes this.
  7. ColoradoBoo
    1,326
    946
    When I was stationed in West Texas (San Angelo), an elderly lady from church asked me to come to her trailer to see what was making all the noises underneath.
    So I removed a wooden panel and crawled under there....a huge possum was right there and hissed at me and showed his teeth just like a cat...made my skin crawl!!! Gonna have to call animal control, Sis!!!
  8. ChapmanF
    18,897
    I surprised two behind a neighbor's trash bin. The adult sensibly took off overland, but the young'un went up the nearby tree in broad daylight and then thought "wait! now what do I do?"
  9. pasadena_commut
    pasadena_commut Senior Member
    2,981
    929
    Southern California
    I wonder what led to that repair? Probably had to replace the connector for some reason, but why?
    On a walk I once encountered a baby possum standing in the middle of the sidewalk. It was at most 4" long. Rather than run away as I approached it puffed its fur up, opened its mouth as far as it would go, and let out the most hideous hiss it could manage. This temporarily disabled me, because I was laughing so hard I could barely stand. Seizing this opportunity, it ran under a nearby bush.
    ColoradoBoo and drone13 like this.
  10. drone13
    140
    115
    SoCal
    Good question. Interesting to note the denso O2 that was repaired was the right part number for the Prius, so a strange case. I'm guessing something snagged the O2 wire and it separated and the guy decided to repair instead of buying a $50 part. I'll bet that if the repair was done with even a modicum of craftsmanship it would have lasted for many years. Either that, or he should have used an entire roll of electrical tape instead of half a roll ;)
  11. ChapmanF
    18,897
    I walked past a bouncing bush once. It was on a neighbor's property, which dropped off a few feet (retaining wall) to the sidewalk. The whole bush was shaking.
    So I stopped to see what the excitement was about, and it turned out to be about a fearless, curious baby squirrel who was walking right toward me on the retaining wall to find out what kind of squirrel I was. If I had put my hand out it probably would have walked right up my arm.
    The momma squirrel had climbed into the nearby bush and was vigorously jumping up and down on the branches, making the whole bush shake.
  12. PriusCamper
    13,351
    5,396
    And you didn't even take a selfie with it?
  13. ChapmanF
    18,897
    Happened before smartphones.
  14. PriusCamper
    13,351
    5,396
    A smart what?
