Have to replace my AC compressor.
Discussion in 'Gen 2 Prius Main Forum' started by Juan Carlos Valle, Apr 22, 2020.
  1. ski.dive
    ski.dive Active Member
    967
    247
    Hutchinson Island,FL. Mt. Snow,VT
    ***It cant be as easy as 4 bolts= Did you have to remove any things in the way of the compressor?
  2. Georgios
    Georgios Member
    126
    85
    Chicago
    The plastics under the bumper had to be moved iirc. But the compressor itself was on 2 bolts and 2 bolts for the lines.
    Data Daedalus likes this.
  3. douglasjre
    douglasjre Senior Member
    2,239
    749
    Null, NL
    I'm confused I thought the condenser coil was in front of the inverter radiator...
  4. ChapmanF
    18,899
    I think it is, but what's confusing?
  5. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    So what TEST was performed to condemn the AC compressor? It's a 3-phase AC motor sealed in a housing that simply compresses the refrigerant and moves it to the condenser. If the compressor is truly "Bad", either there would have to be metal in the AC system (and they did NOT check for that), or it will no longer compress and that is doubtful.
    Can they be killed? Absolutely and DIY or "professional" assassins are the typical causes when wrong refrigerants or lubricants are introduced into the system.
    EVERY mechanic and many automotive YooToobe junkies think they know how to work on AC, the reality is quite the opposite.
  6. ETC(SS)
    7,462
    I'd get a second opinion....and not from a car dealership.
    Unlike the left coast, Miami is both VERY hot and VERY buggy.
    I'm thinking that they have plenty of auto A/C establishments.
    Before I put a new A/C compressor into a 16-year-old car I'm going to make sure that the problem isn't a Toyota dealership's financial problems.....
    ....juuuuust saying. ;)
    douglasjre likes this.
  7. Prius717
    Prius717 Junior Member
    51
    Lancaster County PA
    Did you try looking on rockauto?
  8. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,557
    2,598
    Taylors, SC
    In Miami, the OP has to have air conditioning.
    At $1k to $1500 for a repair and with the car being a 2004 with 200k+ miles, it's time to "bite the bullet" and trade it in for a later model. You can get about $1k as a trade in.
  9. Georgios
    Georgios Member
    126
    85
    Chicago
    To let go of a prius it has to be nothing less than an engine/trans failure.If you trade in for any other car that is not in warranty for like few years its even bigger risk. $1k is probably better to keep it and most definately you can gat more than $1 for the pars depending
  10. Georgina Rudkus
    3,557
    2,598
    Taylors, SC
    You are assuming, that with 214k miles, everything will last forever.
    A used Prius with 30k miles has a better chance of making 200k miles than one with 214k to 350k.
    You may be, but I am not a gambler.
    #30 Georgina Rudkus, Apr 24, 2020
  11. douglasjre
    2,239
    749
    Null, NL
    How would a hot inverter rad temp effect the condenser if the air goes thru the condenser first?
  12. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    See TMR-JWAP's post (post #16) which explains the relationship that the inverter cooling has to the A/C compressor.
  13. ChapmanF
    18,899
    It could indicate overheating of the inverter, which contains (in Gen 2) the electronics to supply power to the electric A/C compressor, and will start shedding electrical loads if it overheats.
    douglasjre's profile indicates having a Gen 3, which is different; the compressor's power electronics in Gen 3 are inside the compressor itself, and cooled by the refrigerant, instead of being in the inverter and cooled by SLLC. But this thread started out about a Gen 2.
  14. ski.dive
    967
    247
    I would take it to a Prius repair shop=NOT the dealer.
    Miami Hybrid
    Hybrid Car Repair
    Address: 12134 SW 117th Ct, Miami, FL 33186
  15. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    1962 fridge, and still in good shape? What brand is that? Can you remember?
  16. CYoung
    CYoung New Member
    Sacramento
    I'm just finishing up replacing the AC Compressor, Condensor & Radiator on a 2007 Prius. I was able to get a Refurb Compressor on Ebay for a couple hundred dollars.
    SFO likes this.
  17. Jeet4510
    Jeet4510 New Member
    Morrisville, NC
    Hello, I am new to fixing hybrid vehicles. Would you please help me?
    I have to replace compressor on "2011 Toyota Prius 4 Cylinders N 1.8L MFI HEV DOHC", my only concern is not get electricuted :)
    so as you mention, after I remove SERVICE PLUG GRIP and disconnect negative 12v battery cable, do I need to worry about anything else?
    Thank you very much.
    Jeet
  18. Jeet4510
    Jeet4510 New Member
    Morrisville, NC
    Jeet
  19. dolj
    dolj Senior Member
    8,631
    4,385
    Yes, you need to wait at least 5 mins after removing the service plug grip, and also after that time check the high voltage connections with a voltmeter to ensure there is no power at the connections, that's if Gen 3s are the same as Gen 2.
    By the way, this is a Gen 2 thread in a Gen 2 forum that you have tagged onto and as I just mentioned your car is a Gen 3, so you might get better advice by asking this question in one of the Gen 3 forums.
  20. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Gen 3 is high volt dc to compressor that has its own inverter built in.
